0 Members and 148 Guests are viewing this topic.
Hoppy
Hi all,
There is an interesting aspect to URFA's setup, in that his 24V supply for the Kacher is being drawn through the 50T-60T toroidal transformer winding which is also receiving induced pulses from the 10T-12T winding feeding the supply to his push-pull PWM oscillator. I think his idea here is to pulse the Kacher in synch with the PWM. Looking at the length of his spark, it looks to me that the supply voltage is a lot higher than 24V.
The diode he shows (as a capacitor symbol) is acting the same as Ruslan's two parallel diodes but just in a the other leg of the 28T yoke winding. However, I do get a brighter bulb using his diode connections.
Void
Quote from: skywalker66 on November 12, 2014, 03:21:47 AM
But your aluminum foil must not form closed loop ( a sort of short turn). It may work if a split is provided in aluminum foil, like in Akula first device or cibinidze device.
Hi skywalker66. Yes, a slit in the copper or aluminum foil cylinder would likely be necessary
to reduce eddy current losses for the waveform on the inductor winding.
The main point I was trying to get across was that my tests have indicated that a foil cylinder
seems to transfer energy to the grenade coil about the same as the 'antenna' winding, so
based on those tests the main mode of transfer from the 'antenna' appears to be via the electric field.
This makes sense since the top of a tesla coil running at quarter wave resonance is a voltage node,
and you should have max E-field at this point. That is why I tested with the foil cylinder, just to confirm.
All the best...
Jeg
Quote from: Hoppy on November 12, 2014, 09:40:07 AM
Hi all,
Indeed it is a clever way for synchronizing if this is the case! I had report before two weeks that only by connecting a diode from grenade to ground I am getting the effect. But it is low in gain compares to Urfa and Ruslan. I am suspecting that John has right about grounding the thick part of grenade.
Void, I tested today the direction of the radiator. I see the effect in both ways, but in one way is bigger. Of course that doesn't mean that radiating with a foil will be less than this. I just report it to take an idea. Well done with your experiments.
Hoppy what kind of ferrite toroid is that? It is a nice idea to try it. Perhaps Urfa can say us ;)
Hoppy
Quote from: Jeg on November 12, 2014, 02:46:06 PM
Jeg,
I don't know. I've asked URFA in an earlier post if he could give us details of the toroid.
I have found that my Kacher output reduces when the grenade is earthed at the thick end.
Jeg
Quote from: Hoppy on November 12, 2014, 03:51:52 PM
It is normal due to the higher resistance path but did you notice something related with the effect? I mean does your system show something different?
About the toroid, i think it worths the try. I have some toroids with very high perm up to 100Khz. You think it will do the job? What about these capacitors before and after the second choke to katcher? This 1000uF cap you think it won't absorb the peak?
