0 Members and 570 Guests are viewing this topic.
Hoppy
Quote from: Jeg on November 12, 2014, 04:13:36 PM
It is normal due to the higher resistance path but did you notice something related with the effect? I mean does your system show something different?
About the toroid, i think it worths the try. I have some toroids with very high perm up to 100Khz. You think it will do the job? What about these capacitors before and after the second choke to katcher? This 1000uF cap you think it won't absorb the peak?
Since I placed the rectifier diodes in the ground leg, the pulsing effect has ceased.
I've tried a second winding over the PWM supply choke winding at twice the turns and this does transfer the leading edge PWM pulses to the Kacher but I see no increase in Kacher output. A high perm toroid may be necessary.
URFA
Quote from: Hoppy on November 12, 2014, 04:22:47 AM
Hi URFA,
I don't see the 10-12T and 50-60T toroid shown on your circuit schematic in your videos. I see a small TV ferrite yoke and this has two windings but with a different number of turns. Could you please give us some more detail on the ferrite chokes / transformers used in your device.
The performance of your device as shown in the videos looks closer to what we all should be aiming towards. Ruslan's video's show his lights illuminating without any pulsating or variance and this looks suspicious to me.
Hi Hoppy.
I used green coated "MnZn" big toroidal ferrite for supply to my push pull PWM oscillator and kacher.Ferrite core size: OD=63 ID=38 H=26mm
http://www.aliexpress.com/item/R7000-MnZn-big-toroidal-transformer-ferrite-core-ring-T633825-in-green-for-machines-50pcs-lot/535635431.html
In my videos I didn't use my last schemastic. I used this schemastic:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/6540/#.VGPh6DSsU-8
URFA
Quote from: Hoppy on November 12, 2014, 09:40:07 AM
Hi all,
There is an interesting aspect to URFA's setup, in that his 24V supply for the Kacher is being drawn through the 50T-60T toroidal transformer winding which is also receiving induced pulses from the 10T-12T winding feeding the supply to his push-pull PWM oscillator. I think his idea here is to pulse the Kacher in synch with the PWM. Looking at the length of his spark, it looks to me that the supply voltage is a lot higher than 24V.
The diode he shows (as a capacitor symbol) is acting the same as Ruslan's two parallel diodes but just in a the other leg of the 28T yoke winding. However, I do get a brighter bulb using his diode connections.
Hoppy.
I want to tell you something. Ruslan's and Akula's device working on same principle but working different method. Akula's device is more complex than Ruslan device. It is difficult to solve Akula's device(without oscillascope it is impossible). Ruslan succeed to replicate the Akula's device. But Ruslan was be lucky, because he succed replication of Akula devices in a simple way. Not like Akula.
In order to operate this device, it have to be the senkronazisyon between Kacher and PWM. Without synchronization this device never working. In this device must be synch for OU. We have to do the this senkronazisyon.
Please Look at this photo what  I attack. This is first video of the Ruslan. Look at output of the Ruslan's device please. What do you see? I see 3 capacitor and a diode bridge and power switch for load bulbs. Do you see anything else?
URFA
And look at Akula's first device. There are also same parts. Needless to other parts. And without ground. I believe that Ruslan's and Akula's device can work without ground. But with grounding works  more powerful.
Ibrahim
URFA
This is an old post of the Akula:
РОМАН КАРНОУХОВ[/size]
[/font]http://cyberenergy.ru/generator-kapanadze/bestoplivniy-generator-kapanadze-t2-3910.html[/font][/color]
Противна слушать балтунов и обидно за практиков!!!! [/font]
Все говорят говорят и расуждают !!!! А те кто делам занят начинают митаца от теори к теории несут затраты по их проверки и самое обидное что те кто рассуждают прям гуру вмире электроники а сами преобразователь простой сабрать не могут !!!! (http://www.overunity.com/file:///C:/DOCUME~1/ibrahim/LOCALS~1/Temp/msohtml1/01/clip_image001.gif)
Для всех практиков !!!! У меня этот или падобный Капанадзе генератор работает давно я им обагреваю дом и все быт. приб. с активной нагрузкой !!!![/font]
Рад памочь каждому кто хочит собрать это дома и для дома!!!!
контакт email akula0083@mail.ru skype akula0083
Немного паесню для того чтобы вы не лезли вовсякие дебри такие как резанансы и как накачька это все интересно но для эксперементав я бы сказал для разново рода игр!!!!
Наша первая и оснавная задача это усилить ток !!!!
Я вижу два способа:
1вый - Это когда мы берем готовое наприжения и пропускаем его через усилитель.
2рой - Когда мы формируем нужное наприжение прямо в усилителе. Кстати у капы это 2рой у него инвертор тоесть транс инвертора находица в поле создоваемым усилителям.
Тоесть собирайте простой преобразователь 12-220, 24-220, 36-220..... ну каму как удобно или у каво какие радио детали есть. Трансформатор помистите во внутарь поля создаваемое индуктором от простой индекцыоной схемы. Для весомого результата поле должно иметь силу которое можит нагревать металический предмет равный по размерй трансформатору преобразователя !!!!
Тоесть это наблюдение из собствиного опыта берем кусок жилеза примерно таковажи размера как наш трансформатор на каторам собран приобразователь и помищаем его в индуктор включаем индекцыонную так сказать печьку и если метал нагреваетса достаточьно быстро ну гдето за 120 секунд его уже становица сложно держать в руках все будит работать.
Сложнасть в том чтобы намотать обмотки преобразователя так чтобы ток создоваемый индукцыонным полем немешал работе транзисторов или теристоров формируюших 220вольт 50 герц. Вот тут выеживайтесь как хотите хотите матайте бифиляры хотите ставте промижуточьный транс.
Re: 's fuelless generator Kapanadze
Message ROMAN КАРНОУХОВ » 06 Jan 2013, 18:16
Contrary to listen all addle eggs and it's a real shame for experimenters !! all they do is say say and discuss!! And those who start with experiments  and move from theory to theory bear all the costs on their verification and what is pity are all those who only talk are straight guru in the world of electronics and themselves they can't make simple inverter !!
For all experimenters !! I have that or similar WORKING DEVICE LIKE KAPANADZE and working for me a long time. I have warmed house and all domestic devices with active load working on him!!
I am glad to help anyone who want to build and get it for home and for the house!! Contact email akula0083@mail.ru skype akula0083
A little elucidation  to ensure that you're not getting at any jungle such as resonances and excitations !! This is all interesting but only for experiments !! I would say different kinds of games!! Our first and the basic task is to increase the current !! I see two ways to make this. First  is when we take some ready voltage and convert it through the amplifier. Second when we forming needed voltage right in the amplifier. To the point of matter in Kapanadze device main role play the second inverter - in fact trans of inverter which was placed in the field built by amplifier.
Make a simple trans 12-220, 24-220, 36-220 how to be at one's ease or how one's have radio parts. Put the trans in the field generated by inductor of a simple induction heater scheme.  To make a tangible result the field must have the force to heat up the metal object which is equal in dimension with trans . This is an observation from my personal experience... take a piece of iron about the same size as our trans and place him in the inductor – turn on induction heater as so speak and if metal warming very quickly, well somewhere about in 120 seconds and if already difficult to keep metal in the hands all will work.
Complexity is in that to make windings of trans on such a way so the current build by inductor don't  hamper the work of the transistors or thyristors  shape  220 volt 50 hertz.
Here do as you want....wind bifilars or if you want put intervening transformer.[/size]
If you can make senkronazisyon in this device it will work. And it is OU.
