0 Members and 570 Guests are viewing this topic.
Jeg
Quote from: URFA on November 12, 2014, 06:41:29 PM
In order to operate this device, it have to be the senkronazisyon between Kacher and PWM. Without synchronization this device never working. In this device must be synch for OU. We have to do the this senkronazisyon.
Thanks a lot Urfa! You are very clear and helpful. ;)  I just wonder is that the synchronization that makes your system so powerful or your unusual high voltage output in general?!
Free energy info thanks for this circuit. Do you know who designed it?
skywalker66
Quote from: Jeg on November 13, 2014, 07:50:53 AM
Free energy info thanks for this circuit. Do you know who designed it? And what is this green coil which looks like a quick grenade's drawing?
Schematic is draw by enjoykin4, based on URFA setup from video, but schematic not accurate.
Jeg
Hoppy
Today I have been trying to produce the flashing lights effect that we see in URFA's videos. I started by taking the Kacher 24V supply from what he calls the synchronisation point 'B' (shown on a previously posted schematic from URFA) via a series connected 148uH choke.  This did not appear to show any effect, so I removed the 470uF electrolytic cap that I had on the output of the PWM / push-pull supply filter, leaving 470nF cap across the output. This started to show a little response as I moved my hand across the antenna and saw the lights varying a little in brightness. It was not until I started altering the frequency of the Kacher with a ferrite rod insert that I saw the maximum effect and this was with the kacher operating at around 950KHz, where the effect peaked. The effect was not as great as seen on URFA's video but the Kacher was having a pronounced effect on the brightness of the bulbs. My grenade coil frequency 1/4 wave is as previously reported - 1.316MHz and PWM is running at 21.9KHz. I don't think that I have so far optimised the value of the series choke for max effect. I suspect that URFA used one of his green high perm toroids for his choke. I have noticed that the amplitude of the Kacher waveform increases a little when the device is connected to my domestic earth. My power supply is isolated from earth.
