0 Members and 672 Guests are viewing this topic.
itsu
Trying to tune the kacher to the Grenades resonance frequency by varying the kacher frequency via a ferrite rod
and monitoring the grenade coil output (everything connected).
It shows a nice peak around 1.68MHz, so my guess is that that is the resonance frequency of my Grenade with everything connected (ground).
The same methode for the bifilar inductor shows NO peak, so i think i need to tune (lengthen or shorten) this coil.
My goal would be to have a peak on the both coils on the same frequency, then divide this frequency by 60 (or 50) to adjust the TL494 PWM
frequency to this.
Video here:  https://www.youtube.com/watch?v=zQrXo-htBQ4&feature=youtu.be
Regards Itsu
Hoppy
Quote from: skywalker66 on November 14, 2014, 07:30:55 AM
Let me see if I get it straight. You put 21.9khz from your FG on inductor and get 1.316MHz on grenade as response ? Maybe some sort of ringing effect? Your method is quite unclear for me.
No. When I originally manually scanned my grenade coil without inductor coil, I could find no resonance under 5MHz, which is the maximum frequency for my FG. After I wound the inductor coil onto the grenade, I found that with around 480nF series capacitance in the inductor / 3W yoke circuit, I had a peak amplitude at 1.316MHz and brightest bulb when my PWM frequency was 21.9KHz.  When I set the Kacher frequency to 1.316MHz, I then noticed the pulsing effect on the lamp that I reported. I also got the highest amplitude and sharpest mustache waveform with this tuning. I basically adjusted my PWM frequency for various inductor cap values until I found the best response. Not perhaps the best approach but nonetheless one way of tuning. I get poor grenade output with higher value caps, so I cannot understand how some experimenters are getting good performance by tuning with caps of 1uF and higher.
Hoppy
Quote from: itsu on November 14, 2014, 04:13:52 PM
frequency to this.
Regards Itsu
Hi Itsu,
This looks like a good way of tuning. I shall try your approach.
Hoppy
John.K1
Hi Itsu,
Thanks for your video. Interesting idea tuning by ferrite bar.
I want to try  to change my antenna it in to the Tesla torus style. I have made a torus from hoover's hose, unfortunately I found the aluminium tape I have is  not a real aluminium :). Have to go to the shop tomorrow to get some. :)
The next thing, what mess my frequency is connection of the grounding cable. In my case around 11 meters of ground wire.  I took two cooper plates and isolated them between by kitchen foil. Such a primitive capacitor, just to get physical disconnection but close enough to suck some electrons from or to the wire :) Than I performed a test. I set my device to lit the bulb. When I connect the ground straight on the bulb-it  dies. When I connected one plate to bulb and other to the ground, the light intensity increased. I migh to try maybe Barnosa&Lela style by wrapping ground  wire around the insulated grenade coil wire.  Speaking just about the wave length resonance -the grenade doesn't change, because here is no physical continuity. So I do not need to think how to re- tune the inductor. And the change of the LC resonance doesn't bother me. As Ruslan said- Forget to search LC resonances- there is only one and it is three turns on the TV yoke."
Itsu, btw, your three turns on your yoke looks very close to hat 26 or 28 or what ever number of turns you have. By Ruslan and Akula there should be some bigger gap.
NickZ
   Itsu:
  Thanks for showing us your current set up, which will hopefully work (in time), as good as it looks. Your work is the best replication I've seen yet. Best of luck.
  If you remember the GeoFusion MRG tests, the bigger output air coils could also be tuned by inserting pieces of ferrite into the former tube, but not a whole rod, as smaller pieces can be separated for best effect, and a rod can't. Also a rod does not act the same by just sliding it in and out of the tube, as the separated pieces of ferrite can.
  I also tune my yoke frequencies, by placing magnetite (not ferrite), on the yoke core. You might give that a try.
  Even though Ruslan didn't use any ferrite rod, pieces, or magnetite.
I found that I could light 7 100 bulbs, or more, using that method. But, not so without doing that.
  Also, for me, placing ferrite into the Kacher tube only could decreased the output frequency, but could not increase it.  At least that is what I found.
Other Exciters that I made (and I built many), did give more light at the bulbs by placing ferrite rods, inside the former tube. But, not with this type of Kacher set up.
   I will also be tuning and testing the Kacher/grenade combo in a couple of days, as I ordered some more transistors from RadioShack here in C.R., although not the recommended ones, as they don't carry them, or the right fets, either. Hopefully the fets I ordered from China will not take too long.
