0 Members and 748 Guests are viewing this topic.
Jeg
Quote from: Hoppy on November 16, 2014, 04:55:53 AM
Yes, Anti-clockwise = counter clockwise: Both valid.
I think I have copied Ruslan's winding directions correctly from studying the videos of his claimed self-runner.
Me too but sometimes i wonder if i made a mistake on somewhere. By opinion is that Ruslan pushed us in the wrong way because of many reasons easy to understand. But this can not stop us from implementing a device on a right base.
Hoppy
Quote from: Jeg on November 16, 2014, 05:08:12 AM
Yes, that is a distinct possibility. However, its also a distinct possibility that he may not know how to achieve self-running. Look how many prototypes he has strewn around. He's probably as frustrated as we are. i blame it all on Kapanadze and that Akula chap.  ;)
itsu
Quote from: John.K1 on November 15, 2014, 05:23:17 PM
Hi Guys, to be honest, as I listen Ruslan to speak about his experience with this device, he speaks sometimes spontaneously about his findings it would be very hard to believe it is fake. Or he is very very good actor :) For example he was saying his device stop working one day and he found that some technicians braked grounding of the central heating by plastic pipe. Ruslan  make them to ground system again. Personally I believe this device IS Real.
Now, finally I got a time to connect all the wires and components and to clean up the space and I have ran the first test. For three turns coil I use 0.9uF and for accumulator 1uF  , both microwave caps (without 10MOhm resistor which I took out)   I use also the diode, which was together with that caps, not sure what are they, but I guess its build for high duty.
My system doesn't work yet. Need to do some tuning and syncs. On the diode bridge (without the cap as on the schematic) I read around 120Vmax @ 14.7 KHz of thePushPull frequency.  The scope shows some fuzzy shapes but what bother me is, it also it shows the frequency 1.34MHz which is below the natural frequency of my grenade coil  (1.84MHz)  , and all this without using the ground. The ground is the other story, when I connect it to my system, power goes down. I will need to tune my catcher I guess again.
I made some torroid with 1 Ohm resistor to check amps on the inductor coil and nod good at all :(  Just around 0.3A.
Thanks for comments, suggestions... ;)
Hi John,
nice build, looking good.
Be aware that the 28 t and the 3 t secondaries on the yoke could be "out of phase".
Swapping one of those coil leads might change a lot, it does with me.
Regards Itsu
itsu
Quote from: Hoppy on November 15, 2014, 06:00:39 PM
Yes, my primaries are cw-ccw.
My yoke primary and secondaries are ALL wound CW......
why?   because studying the videos and pictures is showing this, like this snapshot from one of Ruslans latest claimed selfrunners.
It clearly shows here that the (2x 12T) primary is wound ALL THE WAY CW.
Regards itsu
Hoppy
Quote from: itsu on November 16, 2014, 07:21:16 AM
Regards itsu
Yes, my primary is also wound CW all the way. The winding should not change direction mid-way! I agreed with Jeg because I was assuming that as he is saying his winds are in two directions, he is using the centre-tap as reference point and looking in each direction towards the ends of the winds. Note from his post that he talks about the 'two primaries'.
Hoppy
