0 Members and 610 Guests are viewing this topic.
starcruiser
In Ruslan's video he shows a ground plate/wire as part of the "Grenade" coil, this is the other part of the antenna (ground plane) IMO. I do not see this on Meno's diagram. The HV rectified output is then fed to a chopper FET thru a transformer to step it down, the transformer looks to be 6:1 (50 turns and 300 turns per the diagram) reduction, then rectified again since this is most likely using the kacher operating frequency to drive the chopper/inverter ckt. this output goes to the PSU to create the 12vdc operating voltage.
All this seems to be a Tesla MT setup with a looping setup to self run. We still need to "Match" the antenna lengths to maximize transfer.
FOr those with their coils already wound I would suggest adding the ground inside the grenade coil, a metal sheet of the same mass as the antenna coil, do not short it though, as in a complete circle/turn. this might improve output.
Regards,
Carl
Jeg
Startcruser thanks for transistor suggestions.
Menof thanks for the drawing.
It seems that I was wrong before as now I see what I haven't seen. Yes Menof, what comes from ground to grenade probably is the aluminum foil which is polarized to ground's voltage level. But still something is missing. Capacitors don't charge like that especially through a katcher. Except if it is not a step down transformer but the opposite. Rectified 220V pushed to the output cap which is discharging through grenade.
MenofFather
I think Ruslan say nanosecond generator. But actualy he puting 500-1000 nanosecond pulses to that mosfet in last video, not 100-200 ns, like in Dally divice. With frenquency 15-30 kiloherc.
Void
Quote from: MenofFather on November 19, 2014, 08:11:48 AM
Here it. [Ruslan schematic]
Thanks!
P.S. I think we may still be missing some things here, or maybe I am just still missing some concepts,
but if he is getting near 1000VDC out, how is he looping this 1000VDC back to power the kacher and pulser circuits,
and how is he powering two 240V lightbulbs with almost 1000 VDC? Also, is he still using his push pull driver to power
the transformer (TV yoke core) whose output is being pulsed?
He did seem to have a toroid shaped core on his drawing. For me anyway, there are still various things that are unclear.  :)
P.P.S.
In Ruslan's drawing below of what looks like a toroid transformer, the output is marked 30B or 308? What is he indicating
there exactly? 30 volts? 308 volts or what exactly?
All the best...
Hoppy
Thanks to MenoFather for posting his interpretation of Ruslan's latest hand drawn schematic. I have taken the first step with this schematic by running my Karcher directly into the grenade coil with the inductor left open circuit and disconnecting the supply to the push-pull PWM. I terminated the grenade coil into a 'fast' FWBR with 100nF, 1000V capacitor across the FWBR pos & neg. This gave me a voltage of 76V. Although a long way from 900V, interestingly, when I earth the Kacher to my domestic earth (PSU isolated from earth), the Kacher amplitude increases, resulting in an increase from 76V to 106V. The supply current to the also Kacher drops from 2.36A to 2.24A. When I complete the inductor circuit (not powered by yoke), the voltage output drops.
