0 Members and 607 Guests are viewing this topic.
Void
Quote from: stupify12 on November 19, 2014, 03:07:55 PM
Now your are walking in the right path.. This looks the same to circuit I posted earlier but much more
complicated Hahahaha. I already showed it that the effect you are looking can be done in a simple schematic diagram.
Capacitor can be charge in no time while other winding for the Bulb will light very brightly.  This is simple just follow
the original designer which is Nikola Tesla, I believe Tesla has shown  much easier to understand and to test design with no speculations.... ;)
Keep it simple. Step up the Voltage then Step it down again using only 1 Wire Transmission and Common Two Earth Grounding....
Hi stupify12. If you can demonstrate a working circuit in a video people will be
more likely to take you seriously. People are posting all sorts of schematics here all
the time claiming they are producing over unity, so unless you can demonstrate it with a working
circuit your comments may not be taken so seriously. There are just too many schematics and
unsupported claims getting posted here all the time. ;)
All the best...
Void
Quote from: John.K1 on November 19, 2014, 03:11:40 PM
Now I understand why nobody was able to replicate Ruslan's work :)
Hi John. Could be. :)
Tomtech29
whether you affirm that I denigrate someone or pointing out to bad behavior to whom these words to target?
John.K1 what you had in mind?
stupify12
Hello Void.
Dont take that seriously, You better take Nikola Tesla's schematic seriously.   I think no need to demonstrate a working circuit or a video to take such nonsense post. Yeah, I think I am one of those nuisance on this forum which is somewhat more on posting garbage ideas or schematics.  I will only tell you this see for yourself, before I posted such garbage ideas, it is already proven and tested working,running Two Times with me and my cousin.
Oven diode works much better at the both end of the Tesla Bifilar Cylindrical Wound Coil(which Tesla call Spire Wound). All parts used are from scrap yard, no need such for a high end equipment and colorful windings. All you have to do is BELIEVE on the first designer which is NIKOLA TESLA.
Another nonsense idea- when you read on Tariel Kapanadze Patent you should have a depth understand of how our new High Frequency Inverter of this days work. Relate all operation and parts of Tariel Kapanadze on those little High Frequency Power Inverter then maybe you will see some light.  The Two Transistor on TK's device is a Push Pull configuration for a Resonant High Frequency High Voltage Transformer. Remember there is Two Tesla Transformer- one for the Step UP(Transmitter) and one for the Step Down(Reciever=Radiant Energy Patent)..   Meoooooowwwth this is all nonsense..
Goodluck on Coiling..  ;D
Meow  ::)
Quote from: Void on November 19, 2014, 03:27:51 PM
All the best...
John.K1
Just wonder if anybody here got an effect of bright lite on 20W bulb connected to one end of grenade and the other end to the ground. Yes, without the ground I have a bit of light but when I connected the ground I wasn't able to tune it to the resonance. As the ground wire is an extension I expect to put more wire to my Kacher to reduce the frequency. I made 10x1m pieces of wire and I was adding one by one. My frequency dropped from 1.85MHz to 1.2MHZ with the last piece of wire and no light on the bulb whatsoever. So I started opposite process and was taking off every 30cm. Still no lite. This process I consider as a key one before you connect your push-pull etc.  My ground cable is around 12m long. Quite disappointing.
