0 Members and 699 Guests are viewing this topic.
Void
Quote from: Tomtech29 on November 19, 2014, 04:45:30 PM
the translator reverses the order of words
Brak mi słów by powiedzieć co naprawdę myślę o tym Tłumacz Google Kto dokonuje weryfikacji?
No worries Tomtech. Google translate is not very good sometimes, but we can still understand
a lot of what you are saying.
Witamy na forum. :)
All the best...
MenofFather
Looks that my schematic is corect. Ruslan wrote, that pulses better must be short (150-250 ns). And frenquncy of kacher if 1.5 megaherc, then low frenquency beter must be 15 kiloherc.
"... Снимать энергию желательно импульсами короткими (150-250 нс). Это подбираеться при настройке. И лучше когда частота съёма кратна частоте накачки. Т.е. Качер 1,5 МГц , съём 15 кГц !!!..." - His words...
Jeg
Hi guys.
Just a simple question. Is there anyone here that confirms of getting out 2000V pk-pk from grenade just by kacher radiating? so by rectification to have 1000V at capacitor leads? We use and play with kacher everyday the last few months. Does anyone have such a result?
Hoppy
Quote from: Void on November 19, 2014, 01:36:06 PM
Hi Hoppy. Just to be on the safe side, if possible you may want to try powering the kacher with
batteries for comparison, as since you are using earth ground and the mains neutral is earth grounded,
there may possibly still be some feedback there. Theoretically when you are using a transformer
that isolates the primary from the secondary there shouldn't be any ground loops, but with these
type of circuits it seems it may still make some difference. If switching to a battery doesn't make
any difference then at least you will have eliminated that as a possible interfering factor. :)
I found that when I powered my kacher with a battery, that the output voltage on my grenade dropped
a fair bit compared to when using my bench power supply. My bench power supply theoretically has its output
terminals isolated from earth ground, but it seems the power supply overall is not  Your situation may be different however.
All the best...
Hi Void,
I have powered from battery and inverter and I still see a significant increase in Kacher output voltage level when grounded to my domestic earth but if touch the ground on the device, the output voltage drops a little. This observation was done with just a DVM measuring the output voltage and no scope leads attached.
