0 Members and 124 Guests are viewing this topic.
verpies
Quote from: itsu on September 25, 2012, 10:44:46 AM
lol,  i blame it on the TL494  :-[
TL494 is an excellent PWM circuit.
It is not driving your transformer directly - the MOSFETs are!
Hoppy
Quote from: itsu on September 25, 2012, 10:51:01 AM
Ok Hoppy,  thanks for the info, i will start with the VCO too, what circuit did you use?  the "Dally  2012" with the 74HCT00's?
Regards Itsu
Yes, the Dally 2012. You can also use SN7400's.
I just need the transformer which is on order. What wire did you use for the final HV wrap on the main coil?
Hoppy
itsu
Hoppy,
i bought this cable on ebay:
50 feet HV Tesla Coil Wire High Voltage Cable 24 KV, Belden
and used all 50 feet of it as L4.
Regards Itsu
itsu
Ok guys,
things went much better after i created my ferrite transformer from an old TV yoke which i had for the "yoke project"
It had about 200 turns 0.3mm secondaries, so i added 2x  25 turns primaries which is easy as this yoke is split in 2 (about 400uH / prim).
Nothing is heating up except the both 22K Ohm terminating resistors across the secondaries.
I am pulling 12V / 0.5A, which is much better then my 8A yesterday
Output on the both secondaries is a nice square wave 480V P2P.
The drain voltage shows still some nasty spikes (330V / 500ns), so have to install some 28V zeners later.
Video to be seen here:  http://www.youtube.com/watch?v=Si_vWutds34&feature=youtu.be
Thanks to all for your advices, and on with the VCO / nano-pulser.
Regards Itsu
Hoppy
Quote from: itsu on September 26, 2012, 03:18:42 AM
Ok guys,
Regards Itsu
Itsu,
Thanks for the info on your HV wire. A split ferrite yoke is a good option to the toroid and much easier to wind!
I have attached a Kapanadze schematic of a similar but earlier and more basic form of the Dally 2012 schematic that I saved some time ago. This shows an inverter running at 50Hz, so the Jury is still out as which frequency the inverters on the latest schematics are working at. Anyway, as you are building at 4.6KHz and I'm at 50Hz, we will cover both.
Hoppy
