0 Members and 723 Guests are viewing this topic.
NickZ
  It may also be that Ruslan is not telling all there is to know, or may not know himself the actual workings of his device, or devices. But he certainly can see the results, just the same.
  quote from Geo:
  "Yes very similair to the RMG, but yet as we know RMG draws to much amps at 12 or 24 volts, or even 36 Volts"
   Agreed: But, maybe with the kacher providing the additional impulses in sync, things may change a bit.
  I see more light at the bulbs, if connecting the earth-ground on different points, like at the 3 turn coil's output, (at the 0.47uf cap), or on one end of  the 28 turn's output, compared to the other. Earth ground in now adding to my bulb brightness levels, as compare to before, when no such increase in output was noticed.
John.K1
Guys, I want to say I do not believe it is fake, but I also do not believe it is Ruslan's device :) I am not gonna give-up and it will work ;)
There is something in my mind. Something Ruslan said on forum.  He said "  Wind your grenade coil and inductor. Actually better do not wind the inductor yet, untill you test everything works well...(he probably meant the bulb test)"
Yesterday on my question about he bulb test and grounding he answerd in un-understandable form. But we can pick there the word "Inductor"
Just wondering if I shout unwind my inductor and perform test without it. I will put inductor on something I can slide on my granade coil after.
Void
Quote from: NickZ on November 20, 2014, 12:28:51 PM
Hi Nick. It would appear that Ruslan understands more or less what he needs to do to get over unity.
Yes, it doesn't really matter if he understands the actual physics behind it, as long as
he knows how to connect things up to get results. ;) I have actually been seeing some interesting
things in my testing over the last little while, but I need to run more tests to figure out
if this can really lead to over unity. The interesting effects I have seen so far are either only small and/or
fleeting, so I can't draw any conclusions at all yet. Need to dig deeper into it, but I would say there is
at least potentially some promise there from my own results so far.   ;D
All the best...
John.K1
Just wanted to say to you Void,  I believe the caps can hold more cold electricity than your - our expectation.
MenofFather
Maybe thats helps
https://www.youtube.com/watch?v=uiLY5gQxb_g
http://i45.servimg.com/u/f45/17/25/43/38/smith-11.jpg
And that Don Smith saying about input energy to this divice at the end of this video?
