0 Members and 213 Guests are viewing this topic.
Void
Quote from: John.K1 on November 20, 2014, 01:07:47 PM
I can't say. It says the video not avaliable :)
Hi John. Basically Don Smith just talked briefly about the device that is shown in the photo.
Don said it is milliwatts in and a couple of KW out. However, Don probably meant to say
low watts in and KW out, as those HV NST transformer modules usually draw at least an
amp or two, maybe somewhat less if you have a really low power unit. It appears to be
a HV AC module such as a neon sign transformer, to a FWBR, to a HV capacitor. Then from the
HV capacitor to what looks like a thyristor or similar to pulse the capacitor through the
primary winding or a toroid transformer. It really appears to be almost identical to what
Ruslan showed in his latest video. The problem with some of Don Smith's devices is Don has said on more
than one occasion that he purposely leaves certain things out on his devices in his presentations
because of contractual obligations he had. With Don Smith's devices you are always left wondering
what he may have purposely connected up wrong or left out in his demonstration devices. :)
All the best...
John.K1
Ok, I have probably the same video downloaded. I did study Don Smith in my early stage :)  I bought even the plasma ball to replicate his device:)
Just a thought why nobody I know replicated successfully his device.  I believe the main heart of the device are the caps. I think Don mentioned he has custom made caps.  When I think why, I must go back to T Bearden who has a theory of use " degenerative semiconductor" -.    The main point is, some caps behave the same as that material.
  http://jnaudin.free.fr/html/tbfrenrg.htm
Void
Quote from: John.K1 on November 20, 2014, 01:45:02 PM
Hi John. At this point, you just never know.
All the best...
balphom
am able to charge capacitors with my tesla coil to a voltage more than 1500 very easily. when i put 100w load bulb directly to the capacitors it lights to full brightness. another thing i have notice also when i put the light bulb 100w in series with ground wire it lights to full brightness this shows how much i pump into or out of the earth. i have used akula schematic to drive my tesla coil. although i had to modify them, they did not work for me the way they are drown and this makes me wonder if they are really helping us build the device or lead us astray.
if there is someone out there who can help me in drawing the output circuit after the capacitors i will really appreciate.
the circuit should be able to handle more than 2000v
Tomtech29
Hi
so this is a very good idea, like a bull's eye That would explain the presence of these capacitors ;D
