0 Members and 611 Guests are viewing this topic.
Tomtech29
as a warning when the fun with such a high shock is very probably  for kill.  going to  every light bulb illuminates the full forest
starcruiser
Guys, I still do not see the ground plane inside the grenade coil in your diagrams. Ruslan shows this in his video, i.e. of his hand drawn schema. I think it might be possible that he is using a capacitive arrangement which is possibly
directing the radiant energy through the grenade coil. not hard to add if you already have this built. you can use a split copper tube or perhaps a wire coil grounded on one end.
I highly suggest you try to put a ground inside the grenade coil tube opposite the radiating antenna, this would be connected to ground. the grenade coil should be ran through a full wave bridge (high freq diodes) to the
storage capacitors which then feed the inverter/chopper ckt to the transformer and then the loads.
this kind of remind me of the earlier experiments ITSU did on the coil over the capacitor tests he did.
Regards,
Carl
Hoppy
itsu
Quote from: starcruiser on November 20, 2014, 04:32:15 PM
Hi Star,
i do not see any groundplane in this latest video, could you please show a screenshot or mention the time you see this?
I did do some tests with a Kacher with an extra slotted copper / alu pipe inserted feeding a cap/coil some years ago, but did
not notice anything extraordinary
Regards Itsu
itsu
Quote from: Hoppy on November 21, 2014, 04:10:37 AM
At 2:41 mins in latest Ruslan video.
Hi Hoppy,
just a piece of loose wire i guess as he pans severall times across this while videoing the bulbs.
He must have spotted it himeself but did not worry about it.
Regards Itsu
