0 Members and 125 Guests are viewing this topic.
a.king21
Quote from: John.K1 on November 21, 2014, 04:49:53 PM
Guys, I think forget about that Ruslans antenna. We really should follow Tesla's way. Huge difference. With this torrid anntena my frequency jumped up by couple hundreds KHz and the field around is more intense.
What happened to your input draw?
John.K1
Quote from: a.king21 on November 21, 2014, 10:14:31 PM
Has dropped significantly at the first place from 2.2A to 1.4A. But when I play with the Kacher's 10K potentiometer to tune the shape and hight of the wave  (checked on Kachers collector)  I can go as high as around 3.5A.  There is a sweet spot on my Kacher - I tune it to draw around 1.6A - .From this point the output wave doesn't grows much but the draw grows significantly.
Still, the tuning to the ground it is the pain in a ass.
Also  I got a second thought  - even if the toroid is the right and Tesla way , the wire antenna offers me simple fine frequency tunning by changing its pitch. So I will possibly switch back :)
AlienGrey
Hi to all, Re the Katcher coil, Tesla coil, to get resonance at your chosen frequency, of the Katcher coil, it has to be a pacific length (the wave length), and doesn't the primary also have to be tuned  also to a fixed harmonic, but to get resonance you need to tune the LC of the primary to the secondary. the thing is the energy in the LC has to swing a bit like a curve L to C and then C to L back and forth, back and fourth to transmit the energy, so where is the dynamically tuned C ? (obviously the two coils will have some sort of resonance though out the spectrum), but they will vary in amplitude and at a maximum at true resonant frequency of our wavelength or should do.
Also with the way the primary is wound it has huge dynamic loses, you would think both Akula and Ruslan would have noticed that and stopped the leakage in later devices the way to do it was to use a bifilar wound primary which increased the power locally and suppressed the losses some what. Any thoughts any one, please feel free to comment.
The other thing i forgot to mention is primary orientation polarity, as we are using sine wave from a single ended device, we are pulsing DC not AC, their for the one end of the Katcher coil will be Negatively charged and the other end will be Positively charged, normally the Negative end focuses the greatest collection of charged mater.
Good luck to all.
NickZ
  John.K1:
  Akula also built some higher output self runners that used the Tesla type of capacitor on top, made of the big aluminum flex tubing. But, remember that this type of radiator coil/receiver set up can have an influence in your home electronics, as well.
  This is what I mean,  Akula video:
https://www.youtube.com/watch?v=C03bueW7hlM
  EDIT:
  I had thought previously that half wave DC pulses needed to be superimposed on the Induction coils's AC current pulses.   But now, it looks like the HV Kacher's output, is providing for the negative DC impulses?, to heterodyne with the rectified magnetic induction, on  the induction coils.
So, maybe I had it wrong previously, and now I see the actual way that it's working.  Yes? No?
  AlienGrey:
  Is the Kacher giving off DC then, or AC?  Or both? Is it half wave DC, or, ?
I guess that I'm still confused...
  Here's an earlier video by Lidmotor showing his Exciter using the exact same transistor that I'm using, (which I still can't get to work), TIP3055, same as my MJE3055.
He also mentions that the 2n3055 did not work, as I also found out.
  Notice his Exciter's primary coil, (pancake style windings). To focus the energy only at best spot on the secondary coil, thus producing higher output with less losses.
https://www.youtube.com/watch?v=RWnqLv_PLrU
stupify12
This circuit will still work, if you remember the circuit shown by Ruslan with a diode and a ground to Earth connection. Or a another grounding of Earth connection connected to the base of Transistor. HV doesn't really follow the correct rules of our Electronics of this days.
Quote from: itsu on November 21, 2014, 05:36:05 AM
Hi Jeg,
thanks, but i was refering to the real system, is there a groundplane (copper tube, plate etc.) to be seen there?
Concerning this drawing, there are more connections that does not make sense to me like the Kacher secondary being connected
to ground at the bottom without being connected to the base of the transistor.
Would it work this way?
Regards Itsu
