0 Members and 557 Guests are viewing this topic.
magpwr
Quote from: NickZ on November 25, 2014, 09:28:22 AM
  quote from Hoppy:
  "various observations on Ruslan's videos, strongly suggest to me that he faked his self-running demonstrations.
                              end quote.
  And this is based on just seeing a power supply?
  Remember that no one, other than Ruslan, has been able to replicate the Akula device. Even the Russians have not been able to replicate the effect.
Does that mean that there is no OU, or self running effect?   I don't think so...
  The only person that has even tried to really replicate the Ruslan/Akula device is Itsu.  My hats off to him... As he's really on it, and has all the proper gear needed.  Which not all of us have, or even want.
hi NickZ,
If you are referring to the latest version of Ruslan device.Yes i believe it's actually a decoy/not a fake to lead people away from his working device.
To charge a capacitor around 1uf to around 1000volts DC is easy feat.He is leading everyone including the fellow Russians astray by indirectly telling the multilayer coil task is merely to charge those WIMA brand capacitors to 1000volts for nanosecond pulse generating purpose.That was all i know.
To be Honest judging by the response in the Russian forum couple of weeks ago.It seems only handful of them got excellent background knowledge but was not lead to understand the one of the most basic fundamental of this device which is the harmonics and it's alignment with lower frequency.
Hence yes you are also right no one else besides Dally,Akula,Ruslan in Russia at this point.
If anyone actually believed the crap story about Tariel and those engineers whom approach him for advise had no scope or  a multimeter which can measure frequency and duty cycle %.
To be honest without a scope or at least a multimeter with frequency measurement you or anyone would be stuck from the beginning and it would be end of the road since.
Even "the former team" which was active in the kapanadze thread had all the necessary equipment failed because they did apply "Harmonics" for kapanadze back then.Sadly it is the hard fact.
Yes we are now progressing slowly at a snail pace or baby steps.
If my prediction is correct( :D :D :D ) once many of us have replicated the difficult kacher effect as what URFA and recently Hoppy have achieved.
Only then the handful of capable Russians may able to crack this kapanadze device by continuing from the successful kacher replication as revealed in this forum."It's the only sure way i know to convince someone in a distant land to seriously start working on this device"
The most recent planning which surface in my head is to use nanosecond pulse with pwm generator something like dally device.The output waveform will be stream of nanosecond pulses superimpose within pwm square waveform.
Just one of the upcoming testing stage for tomorrow.
Because of this latest plan i just put pcb design on hold until tomorrow.
Hoppy
Quote from: NickZ on November 25, 2014, 10:50:53 AM
He will continue on and show it working without such confusion.
Let's hope so Nick. Maybe he will start by producing a decent circuit schematic, rather than scribbles on a sketch pad.  :-\
If his intention is to convince us that he is demonstrating a self-runner, then he really does not help himself at all by making it appear that he is turning on that other power supply and placing a board over the PSU, then showing us a lump of wire sticking out of the floor close to the table leg and then panning along the earth cable to the door but not showing the end  ??? I could go on. I call it a piss take!!
NickZ
  Magpwr:
  I am referring to the Akula second device replication that we were all trying to replicate. Others may be referring to the lower output one, which no one has even tried to replicate, yet.
  All I know is, if the yoke core and it's coils is NOT putting out much power by itself, the Kacher is not going to make up for it, to give us a total of 2000+ watts output, as has been shown.
  And almost no body seams to wants to show what their grenade/yoke circuit can do by itself, first. Why? Are you expecting that your barely lit bulbs will become totally lit up by the additional Kacher crt. As the kacher is not really meant to be driving the bulbs, it is only added to create the right heterodyning frequencies.
  Even a single transistor (no other component) Joule Ringer crt can light a 50 to 75 watt bulb, but not a 100 watt, or higher wattage incandescent bulb.
  My point is, why is no one getting their yoke/grenade combo to do anything more that just barely light a bulb or two?
Don't you think that there is something wrong there???   As even the cheapest car inverter can do more than that.
GeoFusion
Hi guyz,
Oh hey about the PSU that ruslan uses, I have the same ones :).
That green light stays on for a while when you disconnect from main.
Untill the cap is totaly drained.
Forest,
Down here I have some of the latest ruslan device schematics, all Variants and picked out from what Ruslan drew in the vid.
To all,
It seems now in my eye,  for every device Akula and Ruslan have build,  are charging these high value caps, as seen in the last vid of Ruslan.
But as we see there are many variants of this tech. But the most important part is to get the right pulses and energy to
keep the caps charged and loaded, and don't forget the ground as for negative ions.
Reminds me of Don Smith device. because it's going the same direction but now without Spark gaps.
All scalar waves and charging , soort of a electro pump method.
Bit of off topic.
been helping others lately converting cars to run on HHO ( hydrogen ), works great for months now.
But today I will begin with my experimentations again, So to test this all out.
wish me luck, yet it's a dangerous path charging Caps of high values. but lets see.
  Will give my updates on the radiant charged system. Also collected a Vasmus Schematic from russians
  will post that one too.
There is a Vasmus special schematic down there ok ;)
Later guyz
  Cheerz~
Hoppy
Quote from: magpwr on November 25, 2014, 11:09:49 AM
hi NickZ,
I would rather put it that the demonstrated device is a fake but that he intended it as a decoy. Everything about its operation was shouting fake to me. As you rightly say, anyone can charge a small cap up to high voltage. This in itself proved nothing. The lamps he kicked under the table never pulsed or flashed once and to top it all, the meter was clearly showing that the supply feeding the HV generator was dropping like it was battery backed.
I must admit that I cannot explain why my bulb can be switched from full brightness to cleanly off, just by moving my hand towards the Kacher antenna. The current draw does drop when the bulb extinguishes, so this is to be expected but what is causing the sudden switching? My initial thought is that it is caused by the kacher field being induced into the induction coil which in turn was working anti-phase with the Grenade coil. However, reversing the inductor leads has no effect. I can even remove the tuning caps from the inductor / 3-wire yoke circuit and earth this side of the inductor coil straight to the main ground point and the effect is the same. Disconnecting the inductor lead will extinguish the bulb but placing just a 100pF capacitor between the lead and ground will fully light the bulb with maximum voltage across it. Can anyone offer an explanation for this?
