0 Members and 938 Guests are viewing this topic.
Jeg
Quote from: Void on November 25, 2014, 12:53:23 PM
Nice video Jeg. The bulb will light brighter with higher kacher drive voltages,
but you are pulling some serious current into your kacher driver to do so.
I saw about 2A at 24V, about 3A at 36V, and your ammeter was pegged at 48V,
so the current was somewhere above 6A it seems. 6+A x 48V = 288W at least.
Your PWM driver is drawing about 6A x 24V = 144W.
That's a lot of input power consumption. I personally don't think this is what Ruslan is doing.
He may actually be running the kacher only at 24V. My suggestion would be to try to find a
kacher frequency (running the kacher at 24V) that causes the PWM input current to drop
quite a lot. If you can find such a frequency, then you may well hit the jackpot.
All the best...
For sure my katcher is far than the appropriate. It needs some modifications. I am just using it to experiment. I had built a Tesla coil once, with 1A consumption at 50V using Radu Morisan's Armstrong oscillator, with an output voltage of more than 50KV! My purpose is just to learn the technique for now. :)
Void
Quote from: Jeg on November 25, 2014, 01:05:45 PM
Hi Jeg. Sure I understand that you are just trying things to get a better
understanding of what happens, but did you see my comment about a different
approach of searching for a kacher frequency that causes the PWM current to drop significantly?
I am personally more inclined to think that this is more like what you will need to see. :)
Ruslan showed an effect in one his videos which appears to point in that direction, but since I don't speak Russian
I don't know how Ruslan described it in his own words. Basically when he turned on the kacher
it caused a 90 degree phase shift, which may indicate that this is completely unloading the PWM driver.
If that is right, you should see the PWM driver's input current drop to its unloaded idling value, such
as maybe 3A or so. ;)
All the best...
Jeg
Quote from: Void on November 25, 2014, 01:14:08 PM
All the best...
Void you are really surprising me! I hadn't heard or seeing something about that! Do you remember which is the related video?
John.K1
Nice words Nick but if  I will start with very basic Katcher/granade tuned to the ground to obtain more power out - in my case it just doesn't work as Ruslan says.
With respect to what Ruslan said:   Kacher making nice wave form -done- no problem here.  Now , he says better not to use much wire on grenade. Optimum up to 40 m.  Grand,no problem here. But than he connect 25m of GND wire which become the part of that grenade coil.  Next what about the inductor?  With the GND wire it is no longer 1/2 of grenade coil. And if I get over this "fuflo" my bulb just doesn't light more with the GND connected to the six output of grenade coil while I did re-tuning of the kacher frequency.  That's why I just gave up and I am tuning it to the natural frequency of the grounded coil as my scope showed me. Didn't get much time to play with it  yet, so some result sometime tomorrow.
Ruslan speaks against  Akula, but he is not able to present his work clearly himself. If I want to get something between people , one tutorial on "how to build it" will do it. From Ruslan I just see working device with many question marks around. One guy with very little experience has working device lie "that" and many experienced guys are not able to make it??  Strange.
  I do not know fake or not. Maybe just attempt to get Akula to release publicly some of his work as they compete.  (like in poker :) In any case, I believe there is free energy but we are probably just on our own. Also some good learning curve ;)
Void
Quote from: Jeg on November 25, 2014, 01:27:52 PM
Hi Jeg. It is his second last video. I would think that you must have watched it.
Watch how there is a 90 degree phase shift increase between the waveforms when Ruslan turns on the kacher.
https://www.youtube.com/watch?v=C8RcRlzk16w
All the best...
