0 Members and 566 Guests are viewing this topic.
itsu
Quote from: Jeg on November 25, 2014, 02:14:20 PM
Thanks Void. It is strange indeed. It looks like his both coils are out of face which is corrected when katcher is on. We need translation...
I think that when katcher is on, because of the fact that coupling is capacitive, this shifts the output 90 degrees as you correctly noticed. But I can't find the link between this (if it is like that) and the lower mosfets consumption.
Jeg, Void,
i had this discussion about the 90° phase shift earlier here with menofFather.
I put up a simple test which shows that a current transformer introduces on its own a 90° phase shift even when measuring resistive loads.
I have a 220V/12V transformer which has a 12V/21W bulb attached.
I measure the voltage acros this bulb, the current through this bulb and the voltage acros the current transformer.
What you will see is that the voltage (blue) and current (green) are in phase as it should be with a resistive bulb as load
But the current transformer voltage (purple) shows a 90° leading or trailing (depending on how the probe is attached) signal, see screenshot.
https://www.youtube.com/watch?v=Nox5tkwjSNY&feature=youtu.be
Regards Itsu
John.K1
 I think most of thinks probably comes out of Alexej Romanov  (friend of ruslan, He is some HiTech electro-engineer)  btw, here is his video of selfruner for couple diodes based on Kacher Brovina ;) https://www.youtube.com/watch?v=PBNNRbhUUnA  Same kacher we have in Ruslans device.
  To understand what kacher Brovina is I was watching yesterday Mr. Brovin talking about some interesting properties of this kacher. It is in Russian so I have to watch it couple times o properly understand, So far  I understood it is really very extraordinary device. Check his video, at the very end he has some schematics.  https://www.youtube.com/watch?v=FNCPv19ujuc&index=1&list=FLPKuZ5HpxDHgqdk-z1JjKCg
NickZ
  Hoppy:
  One difference in the second video link that you posted, is that the 2250 watt output mentioned on the first video, is only lighting two 10 watt CFL bulbs in both videos.  How 'bout showing it running 2250 watt worth of bulbs, a Tv, a Pc, heater, or anything close to 2250 watts.
NickZ
Quote from: Void on November 25, 2014, 04:25:03 PM
Nick, do you have a link to the video where Akula shows that the device keeps running
after he disconnects the ground wire? I can't remember which video that was now, but I remember
watching the video quite a while back.
All the best...
  Void, here it is again, I already added it as an edit to the link that won't open.
https://www.youtube.com/watch?v=cUVvZzeDe5U
  John:
  Romanov has previously never shown a self runner.
The video link with the 3 barely lit led bulbs is no exception.
  Yes, they may know each other, and shared ideas, etz... but that's about it.
d3x0r
a year ago....
https://www.youtube.com/watch?v=a-jnlwkq3O4
http://www.overunity.com/6763/energy-amplification/msg376800/#msg376800
24V .55A (12W) reasonably similar output; except can light an incandescent.
that was a royer sort of driver.
so as a benchmark(not to be off topic) this is failling badly... must have missed something
So akula using the yoke only to drive - no kacher; and ruslan kacher and no yoke...
and the 2 can be combined... as both have
though a yoke only does have a resonanator coil... or... akula had 6 wires 2 to the yoke, 1 ground, 1 load, and 2 more to BR and cap... and PSU.... ?
I expect experts 'know' how the dominoes should stack and stack them that way... when some of them have to be used slightly differently... think there was a fork in the road for resonances and I chose the path more traveled.
