0 Members and 557 Guests are viewing this topic.
d3x0r
Quote from: ismael_34 on November 26, 2014, 12:46:50 AM
     voip
that's a nice idea; but I've had 0 luck inducting anything from one winding to another that way... other than... the blue winding does form 1 turn around the outside... so you get a 1 turn to X red turns ratio induction ... which mean you'd be better to just coil once.
Hoppy
Quote from: NickZ on November 25, 2014, 06:45:43 PM
  Hoppy:
  One difference in the second video link that you posted, is that the 2250 watt output mentioned on the first video, is only lighting two 10 watt CFL bulbs in both videos.  How 'bout showing it running 2250 watt worth of bulbs, a Tv, a Pc, heater, or anything close to 2250 watts.
Nope, you have completely missed the obvious difference! In the first video we see one of those cheapo switched-mode PSU's, which is missing in the second video. Now think and let me know why the PSU is needed in the first video but not in the second.  ;D
itsu
Quote from: Void on November 25, 2014, 07:45:04 PM
Hi Itsu. Thanks for the comments and for the video. Ok on that. That is good to keep in mind that the current
transformer introduces a 90 degree phase shift by itself.
What I was referring to however is not the initial phase shift of about 90 degrees which can be seen on the scope when Ruslan has the kacher turned off.
The phase shift I was referring to is in regards to how the phase shift increases by approx. another 90 degrees to about 180 degrees when Ruslan switches on the kacher. Have another watch of the video..................
Hi Void,
like i mentioned, i discussed this strange 90 degrees flip phenomenon already earlier here:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg422411/#msg422411
Regards Itsu
Hoppy
Quote from: NickZ on November 25, 2014, 05:51:39 PM
  It wouldn't surprise me to hear that all these guys are somewhat related somehow,  or secretly working with the real inventor.
  Will the real inventor please stand up...   Oh, it's the guy with the beard. Oh my!
Yes, it looks like the bearded man could be the brains behind the 'operation'. He does appear to be in control of proceedings during the Kapanadze green box demo, discretely gesturing to the guy beside him who is operating the device. Tariel acts as the front-man but probably has limited technical expertise.
magpwr
Quote from: Hoppy on November 25, 2014, 12:04:51 PM
I would rather put it that the demonstrated device is a fake but that he intended it as a decoy. Everything about its operation was shouting fake to me. As you rightly say, anyone can charge a small cap up to high voltage. This in itself proved nothing. The lamps he kicked under the table never pulsed or flashed once and to top it all, the meter was clearly showing that the supply feeding the HV generator was dropping like it was battery backed.
I must admit that I cannot explain why my bulb can be switched from full brightness to cleanly off, just by moving my hand towards the Kacher antenna. The current draw does drop when the bulb extinguishes, so this is to be expected but what is causing the sudden switching? My initial thought is that it is caused by the kacher field being induced into the induction coil which in turn was working anti-phase with the Grenade coil. However, reversing the inductor leads has no effect. I can even remove the tuning caps from the inductor / 3-wire yoke circuit and earth this side of the inductor coil straight to the main ground point and the effect is the same. Disconnecting the inductor lead will extinguish the bulb but placing just a 100pF capacitor between the lead and ground will fully light the bulb with maximum voltage across it. Can anyone offer an explanation for this?
hi Hoppy,
Around 1 week i had verified there is no changes upon swapping the inductor leads.But this is the primary coil leads i swapped previously and verify there is no changes in waveform at 3 turns."Used scope REF capture feature to verify."
I am unable to comprehend your message "inductor leads" are you referring to the 25 turns bifilar as one of inductor leads which was disconnected from 3 turns/yoke and replace with 100pf to ground.
If so it reminded me of this SR193 device which in the pvc pipe there was a aluminum form as cylinder shape with a gap given which was placed inside the toroid.This aluminum was connected to earth.
(This is similar to closing the loop from antenna to ground but with no actual copper connection)
Your 100pf capacitor also reminded of a ultra simple variable HV 100pf capacitor(High Q field capacitor) which i made using 2 copper sheet one inside small pvc pipe(with gap) and another outside pvc pipe.
Can i verify from you that using this approach of yours there is still output to bulb regardless if mosfet switching a not.
