0 Members and 618 Guests are viewing this topic.
skywalker66
Quote from: John.K1 on November 26, 2014, 06:35:25 AM
Ok Skywalker, first I didn't state it is correct or wrong, second - can you  post corrected version?? BTW, in the last video he was talking about inverter ;)
I don't think there is a correct one Jon, unless author decide by means of a miracle to release correct schematic, which don't happen till now.
"BTW, in the last video he was talking about inverter "
In what context ?
John.K1
Quote from: skywalker66 on November 26, 2014, 06:47:37 AM
In what context ?
Check my post above to Void.
itsu
Quote from: itsu on November 25, 2014, 06:21:59 PM
Jeg, Void,
i had this discussion about the 90° phase shift earlier here with menofFather.
I put up a simple test which shows that a current transformer introduces on its own a 90° phase shift even when measuring resistive loads.
I have a 220V/12V transformer which has a 12V/21W bulb attached.
I measure the voltage acros this bulb, the current through this bulb and the voltage acros the current transformer.
What you will see is that the voltage (blue) and current (green) are in phase as it should be with a resistive bulb as load
But the current transformer voltage (purple) shows a 90° leading or trailing (depending on how the probe is attached) signal, see screenshot.
https://www.youtube.com/watch?v=Nox5tkwjSNY&feature=youtu.be
Regards Itsu
Now knowing the above (that a, for phase shifts uncompensated current transformer (which it is i guess) is causing a
90 degr. phase shift (trailing = inductive)) we can re-analize the below screenshots of the Ruslan traces.
The bottom screenshot shows no Kacher aktive and a 90 degr. phase shift (trailing = inductive) of the moustache like current
in the bifilar inductor coil compared to the voltage in the grenade coil, which now means that the real voltage and current
were in phase suggesting resonance.
However as we are looking at current and voltage in 2 different coils i don't know if that is really the case (resonance).
The top screenshot shows the activated Kacher and we see the current and the voltage now have a phase shift of 180 degr.,
meaning the real current is lagging the voltage by 90 degr. (inductive).
So somehow the Kacher causes the Grenade voltage to shift 90 degr. compared to the bifilar inductor current (most likely), or the
Kacher causes the bifilar inductor current to shift 90 degr. (less likely).
Any suggestions how that is possible?
Regards Itsu
Collapsingfield
Dear Itsu!
Upon my experience by excitation of resonant LC circuit with relative low coupling I think it can be because of some little shift in the freq of the LC by the effect of the katcher.  It is possible insert energy at max voltage, and max amperage as well. It can jump easily from one relatively stabile state to other.
Collapsingfield
Some addition: don't forget that the scope shots came from the not working situation, where only the 3 turns winding is connected to the LC, there is no connection between the grenade and the other secondary of the yoke!
Void
Quote from: John.K1 on November 26, 2014, 04:57:05 AM
Hi void. Regards to Ruslans video
7:00 - 7:36  (not very clear to me, but if I good understund he has on the ferite 2x20 turns (2 coils same direction) made of 1mm2 and on the top 300 turns of 0.7mm wire in oposite direction.
8.05 - 8:40  he is getting on the output 36V & 7A. When he connected invertor there it dropped to 14 V and load max 300W.
About that kacherBrovin, next time. I am now on my tablet - hard to write :)
Thanks John! So it sounds like nothing too unusual about the transformer windings then it seems,
although I have to wonder why he is using two separate windings for the secondary, unless he just
used a transformer he happened to have already.
All the best...
