0 Members and 557 Guests are viewing this topic.
NickZ
   Both Ruslan and Akula are at least kind enough to show videos of their devices.
   Akula's second device has been verified by two witnesses, as working as shown.
  If they aren't willing to fully disclose their device's working specifics, that's up to them.
  However, we can at least see, that there are two oscillators in the Akula second video device, which was also replicated by Ruslan, in his own way.
  There's a magnetic induction oscillator for the push-pull/yoke to grenade, and the 3 turns to the resonator (induction coil) to grenade circuit. And, a Kacher circuit providing for the HV chopper pulses.  That's it, and that's all.
  How we go about tuning the above generator is what we all have to discover.
But, It has been shown working, already, more than once.
  Believe it or not.  It's up to you.
  Without getting into it, and putting it all together,  you'll never know how it works.  That's for sure...
Maybe we won't really need to know how it works, either,
Just to see it workiiiiiiiiiiiiiiiiing, would be enough for me.
magpwr
hi everyone,
I spent about 5 minutes creating this circuit as extracted from Vasmus and applied in virtual electronics environment.
It seems the section of the circuit which i was interested in is functioning as superimposing 2 input signals*eg:tesla coil and one from earth likely in the low frequency range.
The output is shown in the virtual scope in yellow.The blue is the low frequency.
This superimpose part of the circuit is unique and valid in my opinion.
GeoFusion
Hi Guyz
URFA,
I'm very glad to hear what came out of your mind, and yes it's totaly about how to capture and
utilize the Radiant energy as how Tesla did 120 years ago. Check out the pic.
Ruslan is using a mosfet to pulse the collected radiant rectified coming from the grenade and to charge cap fast and using ground.
I think that is where mass storage of energy is located. And Simply use stepdown transformer to 12 - 24 - 30 V for kacher back and pulse circuit for mosfet,  the energy that is still being stored can be used for load as we know it ;)
Yes magpwr,
that schematic of Vasmus looks to me promising, also collected it from russian forum.
Guyz,
I was trying to point out in my last post what is going on, with charging caps, but didn't got any reply or thoughts on.
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg424588/#msg424588
The system needs to charge the caps with the radiant power that it's recieving, either rectifying the recieved energy to caps or direct to
special caps that can be charged with Radiant AC constantly.
https://www.youtube.com/watch?v=yPkHNq6Wji0
Nick,
https://www.youtube.com/watch?v=cUVvZzeDe5U
Yes, I remember that one vid of Akula, and I kind of understand what is going on there,
able to charge the cap in series under the right resonance for pulsed induction  ( Able to operate a normal Tesla secondary coil )
and the Drossil (hendershot coil) inside the output air coils , connected with a cap to keep charging that one, for more output within field.
I think if someone could start replicating that one also they could understand better for what is going on.
Indeed there is no Kacher,  BUT, the output air coil transformer is a Tesla Coil on it's own.
I attached a schamtic of it, so we can share thoughts.  It might be a variant of the First Akula circuit but it's how I see it. Remember
See it as a Tesla coil driver.  I collected alot of variants of the circuit.
In any case today I will be starting my tests ;)
NickZ
  quote from Geo:
   " Nick,
Indeed there is no Kacher,  BUT, the output air coil transformer is a Tesla Coil on it's own."
    end quote.
  Yes, that's how I see it, also. But, it won't work without the additional choke coil/cap inside the pvc tube. As far as I can see, as the big 45 turn air coil may not provide enough voltage output by itself. But with two times 45 turns, bifilar wound, may be enough. Your RMG only needed 80 turns for the 110v output coil. Akula also connected the 220v rectified inverter output to the yoke's 25 or so turn secondary coil. Not sure where the other end of that 25 turn coil goes to, after that. Or just why he did that.
  Main points were, that Akula first video device (still not successfully replicated by anyone), needed no separate Kacher circuit, like is used on the Akula second video devices.  And, it ran without a ground.  Which PROVES that energy is NOT coming from the ground. A battery negative rail can also serve as a virtual ground, as well, or maybe not as well.
  I see it as more similar to the SR193 device, than any other.
SR 193 was another guy that left, without a trace.  Makes me wonder....
Void
I guess there is no reasonable chance than we can get people to stop constantly spamming this thread
with all sorts of unrelated and/or very questionable schematics of unknown origin, and telling us exactly how
we must do things when they have actually no working circuits to demonstrate what they are stating as absolute facts.
Remember ideas are only ideas unless we can clearly demonstrate it with a working circuit. ;)
I guess that is the internet for you.  ;D  I think I will go off on the side lines now for a while and focus on my experiments.
I may check in from time to time, and I will report back if I find anything of interest.
Good luck guys.
All the best...
