0 Members and 162 Guests are viewing this topic.
Hoppy
Quote from: magpwr on November 29, 2014, 08:56:10 AM
hi Hoppy,
There is no mazilli or Houdini for this older device for the unboxing video.Anyone whom plays with just mazilli with external coil would need to create a typical"close loop system" via yoke transformer.
There is no overunity possibility for this type of system whatever the output.
If you say if there is Li-po pack for the latest device "a decoy" without 25 turns bifilar it would still need to be stepped up via yoke and multilayer which is possible using  L/C resonance  to achieve maximum brightness.
Hi Mag,
Its a toroidal core not a yoke doing the stepping-up. Agreed, its not OU.
d3x0r
I was making note of the type of load, because it matters... one cannot be used where the other can be.
Maybe you already knew this; but I don't know everything and the information was new to me.
http://youtu.be/6Jw3zTXsVPo
have to stage the system up sometimes and start with no load, add LED worklight and add others...
Edit: direction of the grenade is important.  the outside should be connected to the diode and the long inner part connected to the capacitor side.  The long side is the longest voltage change, the outside is 'ground'
I have on occasion reversed them, and the oscillations wouldn't work ... to the point that it just totally would not work.
Wish we could have a conversation about how to translate the linear grenade into a toroid...
I see; I remember something somewhere ... the resistive load should be across the coil... as a dampen of the resonance as opposed to power across the cap (DC)... although maybe the inductive load goes there and resistive across the cap...
Interesting to have a system that has the three points distinct...
quick experiment revealed the incandescent can probably go across the coil without so much issue... but then it won't be part of the voltage drop across the capacitor at all... ya.... *edit image*
Also; this longest wound version works best... and if I extend ferrite matter some, I can get more power transfer...
Still need a better clocked mosfet driver; I do know that.
so 48 is not a magic number.
NickZ
  There is no such thing as Over-Unity. There never was, and never will be, as it's just a misnomer.   However, I don't recall ever hearing from any of the self runner device builders, that OU is required, first, to produce a self running device. As the extra incoming energy is provided by the surrounding ambient, in conjuction with an optional ground connection, and not from the device itself.
  Of course, if you think that all these devices are fakes, then you may NEVER know just how they actually work.  Even Ruslan and Akula don't know how they actually work, and keep coming up with different ideas on what makes them tick.
magpwr
Quote from: NickZ on November 29, 2014, 10:51:06 AM
To Nickz,
I think you never learned that to built a device it takes step by step experimenting and you always talk about the end product to everyone which is the "self runner".
I think that is just inconsiderate given that we only received the kapandaze winding procedure like less than 2 months ago.
Ruslan would have started his experiment after Akula or Dally demonstration.That was few years ago.
"Remember the simple Edison bulb was not created in 1 month it was only after 1200 tries or experimenting only then it was successful.
Yes there were many soul whom gave up in this forum from the past to present due to whatever reasons."
John.K1
Nice Nick. Expression of your feelings? :D  Now you professional guys tell me, How to properly tune my Primary to secondary on my Kacher. I am in circle and do not know how to get out of it.  I use simple Brovin oscilator.
Now I have my resonant frequency of my secondary @1.294MHz  and some closests good resonant harmonic of my primary  @1.415MHz
The question is now, Should I change the value of the cap in the Brovin's oscilator, or can i just bridge the primary coil with proper cap to create LC tank?  I know I could play with the tap on my coli but my wire is insulated - so not so easy as to change the value of capacitor.
I believe the tuned Tesla is one of most important thinks to do to obtain free bits.  If properly tuned the input power might be just a fraction of what it takes now while the same output.
One more question: when Brovin is running, my output frequency is around 620 Khz.  A bit different to what the natural resonant frequency of coils?
