0 Members and 287 Guests are viewing this topic.
GeoFusion
Hi Guyz  8)
Take a look at these 2 vids,
1ste vid
with measurments, with 500V 2uf cap 2x, light turns on very dimly.
   https://www.youtube.com/watch?v=C_qdckA6g1g
2nd vid
Without measurements and bright pulse on light bulb, discharge of 500V 2uf cap. 2X
   https://www.youtube.com/watch?v=MzA6qO8qiE4
I've done some testings and gained the same results as this man,  only driving the Kacher  to
radiate the grenade and rectifying output of the grenade to
let it charge the caps and discharging it on a 7 watt 120V bulb, it gives a small bright up time.
I measure  @  ~300V DC on the  positive and negative points of Rectifier
without the caps connected and no load.
but now to make the pulse generator ( A Mosfet or a thyristor in series) work in series with bulb and parallel with cap(s),
to keep a fast pulse and to pump the capacitor(s),
So guessing the Very Fast ( nano seconds ) in Discharge action of the cap is where the massive load exist and connecting
the ground to collect more negative charged particles and to keep the system alive when disconnecting
battery, HV loves ground ( tesla coil ).  what I understand form  now on guyz. ;).
So... massive output discharge of the caps under fast pulses  and able to connect some good load.
Pic below show's the peak of discharge on the x value of Bulb in the second vid.
Cheerz.
John.K1
Quote from: magpwr on November 29, 2014, 12:02:38 PM
hi John.K1,
...For some of us eg:myself,Hoppy,itsu the receiver coil is around 1.6xx Mhz
So your kacher needs to radiate at this frequency.
Sorry Guys I just came back from Santa's Groto :)  Magpwr, Yes I know.  My Kacher was tuned to 1.8 MHz with very little secondary coil. I could lit a 20W bulb until the momment I connected the ground wire (11-12m ) to the 6th end of grenade -  Than I tried to tune to the new frequency by adding more wire (around 10m) to the Tesla and still nothing. So I took the oscillator and checked the natural frequency of my grounded grenade. Yest there was around 1.28MHz some peak but at 580KHz was much bigger. So I putted much more wire to my tesla . Now when it is running I can read around 620KHz-  for now consider it is close enough to that 580KHz - I is not a problem . Now, I am trying to tune my secondary to get most best output.   I have read some paper from Ing. Kopecky where he mathematically describes and calculates the efficiency of resonating system. In resonance the output was 6x bigger with the same input (or in other word 1/6 input to get the same current output on the coil)  Also A. Romanow shows you on YouTube  how he lights bigger load just only from resonance without running the rest of his device yet connected. So guys, thank you for your tuning suggestions and thing RESONANCE :D
itsu
Quote from: pst69de on November 28, 2014, 04:38:14 PM
To whom it may concern, some thoughts that came up studying that Utkin document again (http://www.free-energy-info.com/Utkin.htm)
In my first post i wondered about that capacitve coupling in the antenna grenade combination, now i found a possible explanation on the subject. The Utkin document mentions Avramenko's Plug (Rebuild of a bipolar source out of a monofiliar transmission line). The sections i'm refering are: 1. below headline >POSSIBLE DESIGN FOR THE "CHARGE PUMP" or "CHARGE FUNNEL"< and 2. above and below headline >Alternately charging a capacitor's plates<
The principle is simply that a capacitor under the influence of an changing electric field is sucking charge from ground and stays neutral for the external field after a full alternating cycle (shown in the diagrams  below 2nd headline).
But where are those diodes and plates in the Ruslan device. Depends on the schematic you're using, in the one i've found they are in the following places: diode at the base of the kacher, high current diode between PSU and highcount secondary of the yoke leading further to grenade, one of the plate's is the antenna, the second is the grenade, the "external field" is directly induced to the secondary of the kacher.
Curious. But that configuration even manages to distinguish between a high voltage end (antenna) an a high current end (grenade).
Just some thoughts to get an understanding :)
pst69de,
concerning these Avramenko diodes, are you refering to these 2 diodes (see red circles in the diagram below)?
The one at the Kacher is not on the base like you mentioned but between ground and the return.
If not, could you point them out in the diagram you have?
Thanks, regards Itsu
d3x0r
So; tinkering with some numbers... I found
http://www.ampbooks.com/home/amplifier-calculators/wire-capacitance/
for length of wire by gauge to compute the wire's capacitance..
The spacing is also important... 0.2mm (14gauge) 0.41pF/cm... 4900 cm... 2053pF capacitance for the coil...
at a low frequency (kHz) (low fequency, low inductive reactance to match...
lower frequencies raise capacitive reactance... and since there's a lot of capacitance in just the wire, the frequency should be slightly lower than you'd expect.
I could not detect this resonant point with a scope probe laying across the coil.
410Khz for my 266 uH coil...
a lower uH coil will actually probably have a lower frequency, because relatively it will have a larger capacitance.....
,,, when I fiirst found the signal, I had a +/- huge spike, but the difference was just a square wave...
Oh - the diode and cap across the coil also confirmed lower frequencies that led me to harmonics that might have been interesting...
33,39,45,55,120Khz(!), 240, 480, ...
the cap gets a Dc bias if you connect your scope probe to the other side common to the diode/capacitor... which can break out where there is resonance from where there is just low signal noise.
d3x0r
Quote from: NickZ on November 29, 2014, 02:17:28 PM
  I then restarted this thread which had been abandoned, after Hoppy and Itsu and other guy's tests were not providing for the wanted results.
Several years have past, since then. And my 1800 plus posts prove it.
  Sorry to bore anyone...
Magpwr said he wrote the post that woke this up...
FYI; it's been active for a while with or without you.  it happened at the time that there was also a cross discussion of related topics.
glad you could join...it's a broad and forgiving forum thread.
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg336930/#msg336930  (page 2... first post by me - who cares?)
You keep telling *ME* that *I'm* off topic; sup with that, kid?  what is the topic you think you want me to participate with you that I've missed while working on the broader topic... missing the trees for the forest.
