0 Members and 643 Guests are viewing this topic.
d3x0r
If you're measuring with a scope probe laying near a coil getting inducted... how do you know you're measuing the coil's inductance and not the inductance of the lead and the cap in the scope probe; at some factor rotation from the coil's actual resonance?  At least if I put a LED load on it, I can visually see excessive voltage.  Nailing that resonance correctly, and tracking that one I can move with it... but it's easy to slip from that into other points that look resonant but are not the power.
The signal again without ground was both ends moving in the same way; grounding one end left the other as a real differential even though they started as both high... since the node/antinode was at the ends and in the middle of the coil....
Edit:
Actually I started grounded... that is I had the scope ground attached, and I had a 1uF cap in series with a diode across the coil.  1) real resonance between the inductance and tiny capactiance of the coil itsself should show itself in the capacitor as a DC bias from the middle (diode)... with diode conducting away from capacitor... And then the capactiance of the probe wasn't likely to be participating with the coil's self resonance... I also attached a 25 pf cap in series with the other probe to the scope- but that would just be an AC detector... and was able to see the resonance through that... it was a resonance that passed right through most caps without affecting frequency or amplitude.
The math on the signal between the probes showed exactly the square wave that was the input; but the outputs where in phase highly resonant peeks...
when I really attached ground to the one side of the coil, I got the real resonant differential out; not just the shadow of the square wave... and then disconneting the ground, the behavior remained the same... so it's hard to go back to the initial condition to show......
Void
Quote from: itsu on November 29, 2014, 06:15:53 AM
One thing that looks odd to me is this strange diode/capacitor configuration in this video at the 8:38 minute mark:
https://www.youtube.com/watch?v=kAz0wqQD4Zw
Its not a FWBR configuration, its not 4 diodes parallel its like 2 diodes in series and parallel with the capacitors inbetween.
Hi Itsu. I agree with your assessment of Ruslan's diode arrangement.
I have redrawn Ruslan's diode and capacitor wiring configuration based on what I see, to try
to make it easier to analyze, attached to this comment. It makes no sense to me. Maybe someone
can figure out what this might be for, but I can't make any sense out of this arrangement.
Ruslan seems to have the two parallel capacitors connected where the AC would normally connect in a FWBR.
Maybe Ruslan wanted to form one single diode with 1200V, 24A rating, but in that case I don't understand
why the capacitors are placed in the middle of the diode configuration. Large capacitors will appear
like a very low impedance, even at frequencies such as say 17kHz to 34 kHz. Based on the diagram, the diodes
are not wired in such an arrangement to charge the capacitors with DC. Maybe this is a secret
arrangement to capture and convert radiant/ambient energy  8), or this is just gobbledy-gook, or I don't know
what else it might be for.  :o
Also, see the second attachment. The device shown in this screen shot is in the same box at the bottom.
Anyone recognize what it is? A capacitor? An FWBR? Something else?
P.S. I just tried using Ruslan's (apparent) diode and capacitor arrangement in place of a single diode,
and used it in a half wave rectifier configuration on the greande coil. I don't see any advantage to it over
just using an ordinary halfwave rectifier arrangement. About the exact same output and performance.
I can't see any advantage to it in this basic test anyway. :)
All the best...
NickZ
  I started posting on this thread mainly due to the new Akula 0083 circuit making the seen, then.  Which no one really wanted to discuss in detail on TK thread. And as this thread was pretty much not being used at that time I switched over to comment about the new Akula project, as the Dally replications and discussions had mostly stopped due to no results.
So, from here on (link below)the discussion was mostly about the newly posted Akula device, and further replications effort made by us.
  http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/990/
  I still find what was tossed around at that time worth looking into, again.
  NickZ
  EDIT:  I would like to thank all those involved in this effort. As playing the game is as much fun, as winning it. And all the knowledge gained, is worth more than gold.
magpwr
Quote from: d3x0r on November 29, 2014, 04:46:55 PM
Magpwr said he wrote the post that woke this up...
FYI; it's been active for a while with or without you.  it happened at the time that there was also a cross discussion of related topics.
glad you could join...it's a broad and forgiving forum thread.
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg336930/#msg336930  (page 2... first post by me - who cares?)
You keep telling *ME* that *I'm* off topic; sup with that, kid?  what is the topic you think you want me to participate with you that I've missed while working on the broader topic... missing the trees for the forest.
hi d3x0r,
I took a quick peek at the "old link".I started to laugh now reason being you guys were trying to use the "speed of light" as was taught in school.This was what Hertz was based on.
If you studied All Tesla notes and remember certain key pointers.Tesla mentioned somewhere that we should not use speed of light at all which Hertz was based on.
Copper/Aluminum NMR was used very frequently with no real logical association the kapanadze device.
No mention of harmonics way back then.
Yes i agree without some of you guys like Nickz,yourself and many others the forum would have been dead.If it was dead i would not have stepped in much later on.
Only with the assistance of Menofather after he assisted to create the English version from Akula speech based tesla coil tuning video less than 2 months ago.
Only then i understood harmonics in order to get the important alignment.
Please discard whatever information you have wrongly learned in the past,provided if you can still recall all the important details.Because it is no longer relevant now.
Following  youtube user:Anapa More after he used interrupter with tesla coil video.
Last night i finally discovered the connection from old Tesla article regarding the use of numeric formula.I found out this sub-harmonics are all whole number.Eg:2,3,4,5,6
After last night simple experiment with a standalone tesla coil resonance at 566.5khz.Using just 1 Npn TIP41 base transistor and 10k resistor from base to collector.Bottom of tesla coil connected to base of transistor.Collector  to primary coil.The other end of primary coil instead of being connected to positive i connected to output of inverting MOSFET driver TC4421 acting as postive.
I noticed there is buzzing sound produced from tesla coil only if i apply sq wave signal at 30% duty to mosfet driver acting as positive output and need to use Example at 1/2 resonance of tesla coil at 283khz,1/3 resonance 188khz,1/4 resonance 141khz.
For experiment planned later in the day  i will be connecting this base of tesla coil to earth and primary will be driven by dual mosfet driver at 566.5khz. :D :D :D
NickZ
  Mag:
   Thanks for your comments.
   The Gbluer "Exciter" uses a TIP42 for the 12v circuit, somewhat similar to Dr. Stiffler's Exciter circuits, also. Both developed at about the same time.
   Ruslan has mention the better output gained from the use of mosfets, as well.
   Let us know how it goes with your set up.
                                                               Pura Vida,
        NickZ
