0 Members and 643 Guests are viewing this topic.
stupify12
Simple. A coil that is directly inducing to the other coil will produce 180deg shape. Now Put a Capacitor/or any form of Capacity(Coil) in series with the coil then induced this to the secondary coil. You see a phase shift of exactly 90deg..
Meow
Quote from: itsu on November 26, 2014, 06:56:19 AM
Now knowing the above (that a, for phase shifts uncompensated current transformer (which it is i guess) is causing a
90 degr. phase shift (trailing = inductive)) we can re-analize the below screenshots of the Ruslan traces.
The bottom screenshot shows no Kacher aktive and a 90 degr. phase shift (trailing = inductive) of the moustache like current
in the bifilar inductor coil compared to the voltage in the grenade coil, which now means that the real voltage and current
were in phase suggesting resonance.
However as we are looking at current and voltage in 2 different coils i don't know if that is really the case (resonance).
The top screenshot shows the activated Kacher and we see the current and the voltage now have a phase shift of 180 degr.,
meaning the real current is lagging the voltage by 90 degr. (inductive).
So somehow the Kacher causes the Grenade voltage to shift 90 degr. compared to the bifilar inductor current (most likely), or the
Kacher causes the bifilar inductor current to shift 90 degr. (less likely).
Any suggestions how that is possible?
Regards Itsu
ismael_34
Void
Quote from: GeoFusion on November 29, 2014, 10:34:41 PM
Hi guyz
did you guyz check out my last post? I think it's important material,
I'm uploading some of my own and with some interesting findings.
It's all about Ruslan's latest Device but also a twist of Vasmus device.
Nick check it out, my last post
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg425285/#msg425285
Hi Geo. It is not unusual for a capacitor of that size charged to a high voltage to
be able to flash a light bulb. The capacitor discharges into a fairly low resistance (light bulb)
with a very high current pulse. You can flash the bulb once a second or so
and that is not unusual at all because this slow discharge rate gives the capacitor time to charge
up in between discharges through the bulb. The problem is capacitors of 1 or 2 uF don't
charge really fast to a high voltage unless you have a lot of current available
to charge them. So we can easily charge the cap up in say one second or so without any
problem, but to deliver lots of power out to power a few light bulbs continuously is another story. You would
need to charge the capacitor up say about 1000 faster or so than it normally charges. That
is where the problem lies with this approach. I am not saying that Ruslan couldn't have found some way to
do this, but just pointing out that seeing a flashing light bulb when manually discharging the cap at a slow
repetition rate in this configuration is normal ;)
All the best...
d3x0r
Remeasured resonance of grenade using 24x24 coil around it...
Real resonant frequency is 700Khz with ground with diode and cap; with strong 25V output from 2.5V signal input.
the diode/bridge rectifier was probably an evolution... I tried to build a storyboard of evolution that the BR becomes slowly 2 diodes; and eventually just means to be one.  1) the coil end needs to be grounded freely; 2) the low side of the BR needs to be grounded; now 2 points on the BR are both ground.... But now the capacitor isn't exactly in the right place...
but I've only been talking about this for the past 2 pages.... (sorry still on the topic of kapadze cousin devices; esp. since you both missed the sarcasm... there was traffic here before either of you got there.... so... right.... it's you all you man!)
REsonance on grenade with small additional capacitances...
232Khz  2.2nf
300Khz  1nF
500Khz  500pF
640Khz  25pF
700Khz  0nF
Dangit; actually I'm not using the 266.. I'm just using 2 layers which is around 200uH... tapped in at the start of the third layer (coil cuffed around grenade)
... so my frequency is a little lower than the matched 266uH driving coil... maybe...  *correction again*
700Khz is driving with outer 12 widings on 24+24(+12) coil around the grenade.
900Khz wit 200uH (24+24 windings)
1000Khz with 266uH windings al-together... (+6 more)
Void
Quote from: ismael_34 on November 30, 2014, 01:40:56 AM
    Vacio dos relés
Hi ismael_34. Ok, thanks. You think that they are relays in both boxes.
That could be what they are. If they are relays, then it really raises the
question of what those relays are for...........
All the best...
