0 Members and 161 Guests are viewing this topic.
stupify12
@ Nickz  Bro. This is some suggestion to improve your result.
Tesla
QuoteThe apparatus being arranged as shown, it will be found that when the radiations of the sun or of any other source capable of producing the effects before described fall upon the plate P an accumulation of electrical energy in the condenser C will result. This phenomenon, I believe, is best explained as follows: The sun, as well as other sources of radiant energy, throws off minute particles of matter POSITIVELY electrified
Use the picture attached called Tesla Transformer as a coil to be drive by your Induction Heater, aim to produce 3kv to 5kv(higher voltage is much better to easily see the effect) on the top end. First Transformer follow the Tesla winding of Primary(CW)- then Secondary(CCW).. The Second Transformer follow the Tesla winding direction HV PRIMARY is CW, then the Secondary is CCW( this Secondary coil coil be insulated plated or coil wound like a capacity(capable of charging an electrical conductor)..  The Secondary of the Second Transformer could be plates or coil wound like a plate- Used the Picture of the Tesla Radiant attach on this post. I hope that some may understand how this Tesla Technology works.
Because Nickz you are using a Induction Heater as oscillator- the First transformer on the Tesla Transformer picture, the Line above going to the second Transformer need a spark gap on this Line. Much better if the Spark Gap for impulse should be put on the Lower HV Ground end of the HV Primary of the second Transformer.
Tesla
Quoteead me to conclusions more in accord with the theory heretofore advanced by me that sources of such radiant energy throw off with great velocity minute particles of matter which are strongly electrified, and therefore capable of charging an electrical conductor,
You oscillate the driver in a frequency of e.g 3Mhz, then we extract 60hz on the capacitor? What do you think does the energy on the capacitor being charged could not sustain our loading Capacitor? ;)
Meow... ;D
ismael_34
voip
  dos relés se utilizan para alimentar los circuitos push-pull y Kacher y tal vez la alimentación del ventilador y el poder
también es posible que se alimenta de nuevo a la derecha a través de la interecutor stop motion
John.K1
Quote from: Void on November 30, 2014, 02:03:59 AM
Hi ismael_34. Ok, thanks. You think that they are relays in both boxes.
That could be what they are. If they are relays, then it really raises the
question of what those relays are for...........
All the best...
That relay is for the top buttons on the lid of the box.
d3x0r
Tesla hairpin (tiny indutance, comparitively large self capacitance)
with a resistive load across it....
that's why the picture looked familiar...
These take a time to 'spin up'  Like the +25V wasn't immediately available... and when I scanned the first couple times I totally missed the resonant point.
