0 Members and 143 Guests are viewing this topic.
John.K1
Quote from: Hoppy on November 30, 2014, 01:05:28 PM
Whilst on the subject of concealed components, under the toroidal coil in the first box, he has what looks to me as a commercially built PCB, which I suspect is an inverter or part thereof. The diodes and cap may be Kapanadze style decoy components.
He has said there is a push-pull , transformer and the small PCB on the left is the synchronisation.
ismael_34
[Quote = autor John.K1 fecha link = topic = 12736.msg425456 # msg425456 = 1417373467]
Chicos, poco de teoría. Me tomó alrededor de una hora de traducirlo para usted, así que échale un vistazo al menos [/ quote] :)
John.K1  thank you
Void
Was thinking about it, and here are two possible reasons for putting
capacitors across the AC input terminals of a FWBR. There might be
other scenarios as well. :)
All the best...
GeoFusion
Hi Guyz 8)
  Nick, Void,
Well let's go back very shortly in history about that one and why I did not continue on it.
About my weekly runner or lest say 5 day runner ( is how I call it ) Works great on heavy load, 23~25Khz.
It was the RMG but with a step-down connected to it to the bifilar and rectified
to charge the batteries back (24VoltsDC), it was like a fluffy charge, it charged the batteries well and could run 1 Kw worthy of light but not as bright as grid but bright enough to light up the dark.
But, not worth it replicating, it still uses battery, It's not pulsed. it's High oscillations for massive induction and charge, it functions for a week and kills the battery completely after. but served well. only takes about 2 to 3 amps and sometimes up till 6.
Needed more understanding on these Kapanadze tech and Dally tech.
But After that My interest was on Hydrogen, have some torches that can melt one inch bars in few seconds,  Did it for my cars as fuel ,
,Delco generators on full hydrogen, already heavy free energy and water ( Radiator system) which
creates 150 Gallons a day using ~3kw power from Delco, it's still a source of free energy for everything you need. ;)
Then after some time some months ago, it struck me to know it's all about Impulse. Thnx to Akula schematics and Ruslan and some russian guyz.
All,
I managed to upload 2 vids,
These vids will show some interesting findings and proper understanding what is going on in latest Ruslan device.
Device is working with Radiant energy only using the Kacher on 12VDC,  Freq. of kacher for now on is Unknown. But managed to tune it to the max with the help of meter measurement and output brightness.
Still need to finish testing most other parts but this will take away many doubts. Need to experiment with them otherwise
there is no result.
First part
https://www.youtube.com/watch?v=Bndm38d9TAE
Second part
https://www.youtube.com/watch?v=_rcbT105-aE
Down here is a related Ruslan latest device schematic created by someone on Realstrannik.ru
which shows what they have gotten as info from Ruslan and what he was talking about within the vid.
https://www.youtube.com/watch?v=yPkHNq6Wji0
Enjoy guyz, Let me know what you think and more coming up
    Cheerz~ ;)
d3x0r
Quote from: GeoFusion on December 01, 2014, 02:51:13 AM
Second part
    Cheerz~ ;)
See... straight resistive load doesn't work across caps...   http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg425225/#msg425225
But something like a flourescent bulb, which is a blocking oscillator sort of boost stepup across the cap works... but then that does not work across the coil or any other direction...
Ideally should still be able to keep the resistor(incandescent) across the coil...
Edit:
[strike]Maybe the 2nd diode is useful...[/strike] I put that as an LED load...  but really across the diode to ground... maybe a light in series with that... otherwise it's just a free-spin on the coil ... which is maybe a good thing... looks like a waste of power usually
As I suspected; adding the diode between the coils for low side low reduces the voltage on the caps; and the difference across 'the' diode... which is where I'm getting power right now...
