0 Members and 208 Guests are viewing this topic.
Jeg
Hi again
I am just thinking that if ruslan discharges his cap to a load or somewhere, case no.2 would stop oscillations during discharging. Or at least it will prevent charges to return again back to the discharged cap. It is a speculation though.
About vid. yes i believe that Ruslan is hiding many info about the proper circuit arrangement, and under this hypothesis why not to try some things that we have seen them already in other designs like Akula's or Dally's. Like this tesla tube resonating inside the output coil. (which by the way multiplied a lot my output, and it is my first time that i see the super weak 24V katcher to work).
Just playing and trying new things though. :)
Void
Quote from: Jeg on December 01, 2014, 07:20:01 AM
Hi Jeg. Ok on that. I am still inclined to think that there may really be something to
these devices because Akula's similar devices have been checked out by a few different people
and seem to have not be hoaxes. I don't know if Ruslan really did figure it out, but I still think
that is at least a possibility. His last device is really puzzling however as he did something completely
different, and, as Hoppy pointed out, when you pulse the capacitor bank the voltage on the
capacitors would normally be dropping in voltage a fair bit. Maybe if Ruslan did figure out a way
to pulse the capacitors with very short duration pulses the capacitors might only discharge
a little, like he shows in his video. I don't know though. It still doesn't explain the excess power.
There are suspicious things about Ruslan's devices for sure. :)
All the best...
Jeg
Quote from: Void on December 01, 2014, 07:46:55 AM
All the best...
Ok. Before some days T1000 was insisting that if we discharge a cap up to its middle voltage it would be more easier for katcher to re fill it in a related small time interval. The same time, i remembered Carlos Benitez design where he was discharging his cap (9) inside an other cap (1), which apparently at the end of the process both caps are semi-full. I see a connection on here.
In addition, in Ruslan's new circuit where he discharges his cap through a 300T coil with the use of a mosfet, he probably does the same thing as the coil itself will not let the cap fully discharge as coil doesn't allow sudden current discharges.
Void
Quote from: Jeg on December 01, 2014, 07:56:11 AM
Ok. Before some days T1000 was insisting that if we discharge a cap up to its middle voltage it would be more easier for katcher to re fill it in a related small time interval. The same time, i remembered Carlos Benitez design where he was discharging his cap inside an other cap, which apparently at the end of the process both caps are semi-full. I see a connection on here.
Hi Jeg. I don't understand the Benitez circuit, but under normal conditions a capacitor
actually charges slower and slower, following an exponential curve, the closer it gets to the charging
voltage, as I have explained previously. Something outside of the ordinary (as with all of these over unity circuits)
would have to be occurring to get around this normal charge/discharge cycle of the capacitor.
If the charging source acts like a constant current source, or if the charging source has a very low internal impedance,
then you can charge a capacitor very fast. The power still has to come from somewhere however even in that case.
There is no question in my mind that if these devices are to work we have to find something
that is outside the ordinary. Ordinary resonance tuning and ordinary capacitor pulsing etc. will not likely
get anyone there. What we are looking for probably doesn't make sense from an ordinary analysis approach.
From what Ruslan has showed of his devices, he doesn't seem to be doing anything too complicated,
but it does seem that Ruslan has not revealed everything he is doing, whether secret method or hoax. :)
All the best...
Jeg
Quote from: Void on December 01, 2014, 08:39:15 AM
You find me totally aligned with this, but at the end i feel that radiant energy doesn't obey all the conventional rules that we have learned at school. Anyway, i think that everyday we come closer and closer. ;)
