0 Members and 824 Guests are viewing this topic.
NickZ
  Geo:
   Thanks for the RMG 5 day runner info. I was wondering about that.
  Could it be that the two old 12v car batteries were already discarded previously as not being able to start a car with them? And the 5 day load on them finished them off? But, has little to do with the circuit actually finishing them off?
   Thanks for your resent videos. But, I still see nothing too spectacular about charging the big cap too light a bulb for a fraction of a second. Although it does prove that the Kacher through the grenade set up is working. This test alone however does not prove that the circuit will self run by itself while lighting 1000 to 2000 watt loads.  Nor that the Kacher/grenade are working in sync.
  I'm not trying to be inconsiderate, as I know further testing and work on the device is needed still.
  Last night I connected my Ringer core once again to the yoke's 22 turn secondary coil's output, which is also going through the grenade.
The purpose was to see if taking the frequency that the yoke/grenade is running at would help to sync that circuit with the Ringers HV output.
I was able to light a CFL bulb (60 watt bulb) wireless, or connected to Kacher's antenna coil with that idea. I did this test because I still don't have a working Kacher crt. The results do show some interesting things, and  I will make a video soon to show this, when I do some more tests.
  My Ringer's ferrite core's HV output, with no other circuit components, just the primary and secondary coils of this Ringer, with only one primary coil terminal attached to the yoke/grenade , produces VERY intense RF burns, and this is without any additional circuit or components attached.  I'm in no way able to hold my finger to the antenna coil's HV output streamer, as Ruslan has shown.
Void
Quote from: NickZ on December 01, 2014, 11:15:56 AM
Hi Nick. Although Ruslan used his finger tip directly to show the arcing in one or two videos,
it doesn't mean it didn't hurt a bit. ;) In one video, Ruslan showed that he had a pin hole
burned in his finger tip, and from that point on it seems he has been using something metal
like a screwdriver tip to show the arcing.  ;D
All the best...
NickZ
  Good point, but I can't do that for even a half second.
  My analog meter is fully nailed to the right from the Ringer's output, even when three incandescent bulbs are partially lit, as well as the 60 watt CFL bulb.
  Here's a couple of pics, sorry that they came out so blurry.
a.king21
Void and Jeg re Benitez:
He has at least 2 different principles in obtaining excess energy from the environment.
The principle relating to capacitors is very simple. It is based on the well known facts of electrostatic
induction.
ie if you charge a plate with negative electricity and you earth the plate, positive electricity will come from the ground
to neutralize the charge.  All you do is intercept the surge from the ground
and  recycle the electricity into your device.  There are hundreds of permutations.
Benitez would charge up one plate of a capacitor and allow the earth surge to charge the other plate.
Electrostatic induction is COP 2.  ie buy one get one free!  You do however need to be in the thousands of volts region
for the device to work.  Benitez used a Whimhurst machine to start his device.
John.K1
Quote from: a.king21 on December 01, 2014, 02:12:39 PM
And how it would be with the asymmetric capacitor?
