0 Members and 137 Guests are viewing this topic.
GeoFusion
Hi Guyz
Hoppy,
yes in Ruslan's video we see a constant ~900V across his capacitors, and the lights are super bright and not pulsing slow, but super fast
just like what Vasmus does to his output lights ;).
this is how I see it,
Ruslan is pulsing the rectified DC Radiant very fast with a circuit ( with a THyristor , Mosfet or transistor) , letting the capacitor(s)
charge and discharge super fast, keeping the flash of light alive and steady.
I tried the kacher on 12V car battery and getting same results and on 24V is even greater output which is crazy haha.
Kacher AND  fast pulse circuits with good caps are needed to to operate the Latest Device of which he presented on vid.
Man, the push-pull is not a decoy of any type that is for sure,
Akula's first device was only operating with that circuit TL494 with a Capacitor in series
for reaching resonance with cap to achieve massive energy. Has fine tuning too.
I also have build my Push Pull with TL494 but not using it yet, will try it out soon but the latest of Ruslan is what I want to be focusing on
now.
  Jeg,
Yes, that is the way to go, and Radiant doesn't obey all the conventional rules of electricity that is right, it's different  and beautiful :).
just like Carlos Benitez device. Or lets remember a bit of Don Smith Device Discharging massive Capacitors
worth of 20Amps output in his time. Reminds me now of Kapanadze in the old days.
But in Ruslan's latest, the mosfet will pulse the  rectified DC voltage to the cap very fast, so the cap discharges back fast and discharges
the 300T coil and for load keeping a fast pulse for a steady light and to stepdown trafo for other outputs.
  Nick,
Always willing to share :). it's for the better and learn form eachother and to keep experimenting till we find it.
Yes the 12V batteries were discarded befor I start using them, they wont even start cars.  but charged them abit with a charger I have for
12V batteries.  Guesing the Mazilli circuit is consuming alot of amps and I do see some liquid coming off the negative lead of the battery
over time and crystalizing it to Bliue material. But 1 to 2 kw run is great, but only did it on used batteries :).
My Mazilli has Germanium Diodes Instead of Zeners.
As for the new findings of Ruslan Device , it's very interesting but yet dangerous when charging caps. Those charges can Kill.
Now we have to pulse that 300+ VDC from FWBR coming from grenade with a mosfet to get a faster and continuous discharge from
caps, until we have a steady light. :) that will be the next step.
Thnx for sharing your pics, Btw Should change the wire gauge to 1mm squar on toroid choke or so, les heat on Fets.
looks great with the ringer setup, try to make the kacher work to see what it will bring about ;).
Yes be careful, the RF burns I can get do burn a small hole in my finger now if I do touch, ;D
Oh yes I'm pretty sure Barbosa and leal  device is also related to what we are
figuring out, it's electrostatic and needs the ground, Pulsed system.
a.king,
Thnx for comments and pointers :)! good to have some more brain work around too.
Jeg
a.king21, thanks for the clarifications! Everything start to take a shape. Carlos was a brilliant mind!
From other planet, thanks for the link. Don Smith is one of my favorites researchers. I have replicated his theory about matching wavelengths of prim. and sec. and it is as exactly he states when we wish to take out frequencies like some decades or even hundreds of MhZ. At these frequencies is difficult to tune like Tesla did, and so tank circuits are formed only of the intrinsic capacitance of the cable and its inductance. So matching is necessary in these cases.
d3, can you please clarify what diodes are you talking about? Are you referring to Ruslan's (bruto's) classic schematic?
Nick thanks for informing about Barbosa as there is no time for checking other threads! Ruslan took our minds :D Nice looking setup.
Geo Geo
Your excitement made me from the first time to start this Ruslan and Akula replication tries. I recognize that to you. Keep us informed as we have opened so many war fronts! Let me ask you something. If charging a cap with radiant is the case, why we use Ruslan's grenade and this weak katcher instead of filling caps straight from an NST transformer or ignition coils or even tv flybacks? Don't tell me because of high frequencies because Tesla has made it very clear. If we have to choose between HF and HV, high voltage has the priority! An other issue is that his new design is something different than the old one in terms of principal theory. It is like he tries to take us away from this now that we are so close. What is your opinion on this?
Hoppy
Here is another suspicious looking couple of clips from the latest Ruslan self-runner video. Clue: the hidden battery is probably not in the plastic box under the diodes.
d3x0r
Quote from: Jeg on December 02, 2014, 03:57:37 AM
I'm sorry I meant for Geofusion... was too many pages ago
@geofusion
re: http://youtu.be/_rcbT105-aE?t=7m13s
You should remove the excess diode...
sketch here...
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg425534/#msg425534
T-1000
Quote from: Hoppy on December 02, 2014, 04:19:21 AM
How big battery should be to run >1kW load extensively for 20 minutes?
The answer suggest to throw away this suspicion...
