0 Members and 715 Guests are viewing this topic.
Void
Quote from: thngr on December 04, 2014, 11:22:02 AM
so many fakes in this topic.
kapanadze's device main principle comes from static electricity device like testatika that you do not know how it works! animated electrons like transmission line. But he knows testatika, not Nikola Tesla. for testatika there is moving wall between them.(wall made of isolators and conductors that are same size as charging plates)(them means: charge plates and charging plate)
Hi thngr. If you know how Kapadnadze's devices work, then please provide the details
of how they work. We have people posting here all the time telling everyone how
everything is supposed to work, but they can't demonstrate anything at all to back up what they are saying. ;)
What are you basing your opinion on? Have you built a working Kapadnadze type device?
All the best...
Void
Quote from: ismael_34 on December 03, 2014, 05:47:05 PM
even which also leads me to ask why Tariel Kapanadze's use in testing your garden when connected to the tap and scored 23 amperes
¿  tariel works with 50 hz ground wire ?
Hi ismael_34. I am not sure how Kapadnadze's devices work, but he may include
an inverter that runs at 50Hz in some of his devices at least. I don't know...
All the best...
John.K1
Hi Void, guys,
I was posting here some link where you can see Mr. Brovin speaking (in Russian) about his Kacher.  What wonder me is how the voltage input or height of signal amplitude has big impact on the output. In other words, there is a JUMP in behaviour or output power. Just to find the right sweat spot.
I was just trying to replicate one of his findings today and burned my opto-couple :)  With a very small coil, one transistor and 1.2V input. Before the desister happened I could see on my scope around 210Vpp impulses.  With the increasing input voltage I wanted to reach the state when these peaks fill linearly nearly all area- the Kacher impulses. Yes, with voltage-not frequency ;)
Void
Quote from: John.K1 on December 04, 2014, 04:24:25 PM
Hi Void, guys,
Hi John.K1. I am not quite sure what you mean about linearly filling nearly all the area, and do you mean you
were looking at the waveform on the collector of the transistor, or on the secondary winding?
All the best...
John.K1
Hi Void. Watch video from 17:00 (Brovin kacer: http://youtu.be/FNCPv19ujuc) By changing the input voltage he was able to fill the space on the scope by impulses. And it happend by jump. After he disconected the base of transistor and the kacher process was still running. No input signal- just input voltage source. On the scope you see: top is the collector voltage, bottom is the emmitter curent. Emmitter starts as a sinus and change to saw shape. Togethet with HV amplitude on the collector it is called kacher proces. That's what he says and show.
