0 Members and 138 Guests are viewing this topic.
Void
Quote from: John.K1 on December 04, 2014, 07:31:09 PM
Hi Void. Watch video from 17:00 (Brovin kacer: http://youtu.be/FNCPv19ujuc) By changing the input voltage he was able to fill the space on the scope by impulses. And it happend by jump. After he disconected the base of transistor and the kacher process was still running. No input signal- just input voltage source. On the scope you see: top is the collector voltage, bottom is the emmitter curent. Emmitter starts as a sinus and change to saw shape. Togethet with HV amplitude on the collector it is called kacher proces. That's what he says and show.
Hi John.K1. Thanks. It looks interesting, but I don't really understand what is going on there.
It looks to me like maybe he is driving the kacher circuit with impulses from a function generator?
All the best...
magpwr
hi John.K1,
Firstly i thank you for uploading this Brovin kacher with the formation of nanopulse.
At 5:40min into video i was not able to understand on how he manage to obtain nanopulse from kacher.Any kind Russian member can advise us?
I have attached the screenshot as i am curious to know on how to obtain the nano pulse simply from kacher.This after no input signal at transistor.
After the last experiment using inverting and non Mosfet driver(emulate H-BRIDGE) to drive primary coil which i find produce longer spark length at 12volts as compared to 36volts using single transistor.
I think the above video do hold the key which i am not able to understand due to language barrier.Is it nanopulse to inject to transistor base after square wave signal running at kacher resonance frequency.
In other word is it after square wave it is series of nanopulse then back to square wave.
Time for me to design a circuit in virtual environment to generate this type of signal for testing purpose. :)
Fyi only for example if tesla coil is running at 1.66Mhz the time period is 602ns.
If were to create a nanopulse it would have to be around at least 1/3 or more  of 602ns   ,602/3  = 200.x ns
d3x0r
I got that wave to happen with a very high resistance between collector and base (10k+) and low power... but if you have a good resonant ringing after (like if the grenade is mounted and inducting then it's harder to get these...
lowering the resistance or raising the voltage gets you out of this condition...  if you have a strong enough ringing it is sometimes improbable to tune to get these spikes ... probably better seen if isolated to just the kacher without antenna/other grenade connection....
When I was picking up the 14gauge solid wire coil again to play with; I was putting together my kacher, and only had the primary and secondary, and the grenade was a few feet away on the bench, but had it connected to a load ( a few LEDs from resonance testing), and when I turned on the kacher, it was enough to stimulate resonance in the grenade from a distance....
that's when I figured I had it close enough and started moving the pieces closer;
tried several times reversing the connection on the antenna ... knowing the the grenade was inducting from just the secondary already... but I didn't find it better if the antenna was CW or CCW... didn't seem to matter.
@magpwr
(was it you that had mosfet kacher? you're using a mosfet driver too?  got a simple scheme?)
the line is the collector line; I'm not sure what the sharp spikes after come from... it's not enough kickback to turn off the base... but the spikes are seen on the collector; akula would call it 'ferro resonanace' ... can't say where they come from or where they go... by the time it hits my grenade it's smoothed ....
although at certain low voltage times, I do see this higher frequency mixed in on the grenade's resonance...
Can tune this with variable resistor; if the resistance is lowered enough, (almost to the point of being too much) the spikes after smooth out; one test was seeing which way was better and was able to tune it for the dip, and a single hump, but the return didn't spike, it was leveled out... ran a lot of current in this condition (since base was almost to the point of 100% on) ... seemed to be better to have the spikes than to smooth them.
No help; I know...
Enjoykin
Эксперименты с Качером В.И. Бровина !!!!
Сборка Явление Транзистор Лампа  26,9 MB
https://yadi.sk/d/lIhNqg_uMLVtL
Доклад Качер 63,3 МБ
https://yadi.sk/d/jxJvIwDbKcDH7
Статья в "Мир измерений"  612 КБ
https://yadi.sk/d/WMKSaEM3JEV5L
"В мильен первый раз рекомендую познакомиться с первоисточниками. Мусолите одну и ту же схему. Я ее в прошлом веке приспособил к реле приближения и продавал как устройство охранной сигнализации. Высоковольтной ее сделал и вывалил в интернет mag. Мне он представился Мишей. С тех пор я его не видел, и высоковольтной темой не занимался. Все занимаются а мне зачем?"
Владимир Ильич Бровин
d3x0r
and ... get more russian from those who could help...
Experiments with Katscher VI Brovina !!!!
Transistor lamp assembly phenomenon 26,9 MB
Report Kacher 63.3 MB
An article in "The World of measurement" 612 KB
"In milen first time are advised to read the original sources. Procrastinate the same circuit. I have it in the last century adapted to relay approach and sold as a security alarm device. High voltage did it and dumped the online mag. I introduced himself Misha. Since then, I never saw him, and high-theme was not engaged. All are engaged and me why? "
Vladimir Ilyich Brovin
