0 Members and 599 Guests are viewing this topic.
John.K1
Quote from: d3x0r on December 06, 2014, 07:18:00 AM
these are shots of my kacher running at 525Khz (approx)
noted some frequencies... have fft centered on different frequencies...
Removing scope from circuit, frequnecy goes up to 1.1Mhz  ...
think the ringing at 4mhz is still there....
the 2 and 3 pictures are from a scope lead draped across the kacher...
moved probes to base and collector, which doubled the capacitance and it started to not work...
"...doubled the capacitance and it started to not work... " *Don't touch the brain!*
You need to adjust the resistance to your base. It will get rid off the ringing on your emitter  and will increase the amplitude (and consumption :)  )- at least it does for me.
Is your emitter grounded?-It should be.
d3x0r
Quote from: John.K1 on December 06, 2014, 09:01:50 AM
not really; was tracking the ringing more, and it's all through the system...
so either it's relative to the cap and inductor that is the scope probe... or it's really there
It does disappear if I remove the grenade...
It's somewhat of a particular with this grenade.... I didn't see such ringing before
emitter is not grounded, it's just on the battery.... but both scopes had ground attached to the emitter rail.
Edit ; right so I swapped grenades and the ringing went away.. also had to be a 1Mhz frequency... when I changed back I couldn't get it for a while until I got back into tune with no scope probes... now it's back up to 1mhz and I see the extra ringing at 4Mhz...
changing resistance... can smooth it out; not sure smooth is the right direction to go...
John.K1
I was watching tigers video.  Technically Brovin kacher with the transformer. On the scope he shows Ringing impulses-. He start the process with the battery. Than he takes a battery away and you can see how the amplitude goes down (as capacitor decay)  and back up  ::)  - like self stabilizing process. and keeps ringing, and ringing , and ringing, and.... you know what I want to say :)
https://www.youtube.com/watch?v=QwbMpqqQGLw
Enjoykin
Well Well Well
Some people here - think that everything about FreeEnergy is a fake. And spread their ignorance around making very fine PSY DIVERSIION at mind of other people. For my point of view it is EVIL.
What's the problem than ??
Come on - uncle Sam is waiting for you. Join his DEATH ARMY and
MAKE NEW CAPITALISM NEOCOLONIAL WARS FOR OIL AND RESOURCES. BURN COAL, OIL AND GAS. DESTROY ALL FUCKING PLANET AND IDIOTIC CIVILIZATION. IT IS THE ONLY JOB YOU KNOW WORK - DESTROYING - WHOLE WILD WESTERN CIVILIZATION WAS FOUNDED ON DESTRUCTION AND DEATH !! NO ONE CAN'T ESCAPE FROM THE TRUTH !!
Well - it would not be not the first nor the last destroed civilization in Cosmos.
END OF CABLE !!
For those who are looking for watch Ruslan-X video Katcher 7.
What he has done. He has transformed Katcher high potential on high current. Output 220V, 150W.
Liink is:
http://www.youtube.com/watch?v=4-flVbCreIM
Is there any sencse postштп here or maybe Stefan should wipe out whole forum and find some new job ??????????????????
John.K1
Hi Enjoyiking- some problem there to download "ortogonaltor" :(
Edit:  works now.  Thanks.
