0 Members and 327 Guests are viewing this topic.
d3x0r
@itsu
have you tried a DSRD diode between the grenade and cap?  Should give a nice kickback to the coil....
@else
http://youtu.be/3af2e6JZjVc
48/48/24/24/12/12 ; square ended (non tapered coil)... small PVC - similar to aquarium
same basic schematic...
7W bulbs in parallel
itsu
Quote from: d3x0r on December 07, 2014, 07:05:31 AM
@itsu
d3x0r,
you mean instead of the 2 schottky diodes?
Regards Itsu
d3x0r
Quote from: itsu on December 07, 2014, 07:22:00 AM
d3x0r,
Regards Itsu
yes, if not overpowerd... was a high voltage?
Can you move them to? to the other side of the coil, on the green line veritcal?  between coila nd cap on that side instead?
Not that it probably matters in the long run; just suits my sensibilities so the voltage peek is against the diode at half the cycle  but then it makes it negative biased instead of positive output... so maybe try both places
Edit: the image is wrong... I mean....
Ya... but doesn't it work like .. image 2?
NickZ
  Itsu:
  I've got my grenade/yoke coils working, although with just the smaller fets for now. And I have the Kacher working, also. The problem is that when I try to connect the Kacher's secondary to the ferrite rod, and to the antenna, the output from the Kacher is killed by doing this, and no output is noticed on the antenna coil.
  I also removed the 4 turns of wire (opposite wound) on the end of the Kacher secondary, and now I do get a small spark that does cause RF burns, but minor, compared to the Joule Ringer's output.  But, still no output at the antenna coil.
  Is there something that needs to be done so that this does not happen?
I'm running on a 12v battery charger for the induction crt, and a 12v car battery for the Kacher circuit, for now.
  I also notice that my Kacher's output is rather weak, with the number of turns that I have on the secondary.
  No increase in bulb brightness is noticed when adding the Kacher circuit to the grenade coils, or antenna.
  Here's an image:
itsu
Quote from: NickZ on December 07, 2014, 10:26:38 AM
Itsu:
Nick,  no not that i am aware of.
QuoteI'm running on a 12v battery charger for the induction crt, and a 12v car battery for the Kacher circuit, for now.
Here's an image:
Try to keep the wires a short as possible between the transistor and the primary coil, more like 1 cm then 5cm.
You have lots of wires on your secondary (lots of inter capacitance), it might be that the ferrit/antenna is to much, try to unwind 1/3 and
see if things improve.
Move the primary more to the bottom of the secondary and try to make the primary tap-able to find the correct matching point.
Regards Itsu
