0 Members and 316 Guests are viewing this topic.
itsu
Quote from: d3x0r on December 07, 2014, 07:33:04 AM
yes, if not overpowerd... was a high voltage?
Can you move them to? to the other side of the coil, on the green line veritcal?  between coila nd cap on that side instead?
Not that it probably matters in the long run; just suits my sensibilities so the voltage peek is against the diode at half the cycle  but then it makes it negative biased instead of positive output... so maybe try both places
Edit: the image is wrong... I mean....
Ya... but doesn't it work like .. image 2?
There is like 100 - 150 V DC on the capacitor, so these DSRD's should be able to handle that.
i doubt that we will see any pulses like you have drawn, but i can try.
I have removed the Kacher after repairing my bench PS with the help of ION from OUR forum, and i would like to keep it healthy.
So i am retesting with my nano-pulser (instead of the Kacher) again right now, so need to see if the DSRD's can be tested without the kacher.
Regards Itsu
Jirkason
Hi, this is my test sample test by Ruslan. Test for now tesla + antenna + bifilar winding. 24V power from the battery. The load is a lamp 230V, 25W.
Jirkason
d3x0r
Quote from: itsu on December 07, 2014, 01:42:34 PM
Regards Itsu
There's 1KV on Ruslan's (without load); I got up to 400 and realized my diode limit ran out; put 2 diodes in series now can get up to 800 without a load... when I put my 60W incandescent across it; it shorted and arced and now is dead :)  Wish I lived in a 220 country :( I feel these 110 really limit what I can do
Ya.. the voltage build up is more gradual not as spikey as I indicated
probably too low of a change to be a 'pulse' so maybe no benefit...
magpwr
Regards Itsu
hi itsu,
I understand you have done some research on nanosecond pulse in the forum in the past and you have managed to achieve 800volts peak around 100ns pulse width few years ago in this forum.
I manage to find 3 source of information related to nanosecond generator and containing interesting circuit diagram in pdf.This is also related to my current research to complement my synchronized nano-generator circuit which i have uploaded few times around a month back.
I am more focused on the driver stage of the nanosecond generator at the current moment.
There is a another research done on nanosecond with straight coaxial cable but it did not contain any useful circuit diagram.But there were useful theories to support it.
Dally coaxial cable is the spiral version with shorted end.
Please do take a look at the pdf and other drawings.I hope in doing so we can speed up research in this area.
