0 Members and 71 Guests are viewing this topic.
dvy1214
Not a nay sayer, just have to get this question out there.
What do most of the people on this forum actually think resonance is?
It is most definitely possible to make a kampandze, Don smith, Joule Ringer, WHATEVER resonate with itself. This is the basis for many audio distortion resonators. The question actually is, can the resonant rise be infinitely risen while expanding the amplitude of the wave providing you with enough energy to run a load larger than the load on the power source driving the oscillations. Remember that power is relative but is actual in time. Power over a period none equivalent to the driving source is not proving anything about accessing energy but is creating a masturbatory illusion. Has anyone here heard of the terms analysis paralysis and mental masturbation?
Please, stop using resistive loads to try to show yourself progress you are hurting yourself if you are not using a lumen meter. ANY relatively low voltage source can be run through a resonant transformer to run light. Please for the sake of anybody with a degree who comes across this forum connect your resonant transformer to an inductive load driving an alternator to recharge your source. You would be much better off working with that as your bar. Raise the Bar from there. Working with light bulbs will only leave you very sour when you then try to connect a motor to do work. JLnaudin wouldn't even pretend to make a false claim about this because it is in fact a very efficient transformer.
http://jnaudin.free.fr/kapagen/kapagen33pio.htm
I know that what is being worked on in this thread is different from kampandze but bear in mind that principle is principle is principle. I am not saying this stuff to be a troll. I am saying this stuff because there are people actually trying to learn a thing or two and intellectual dishonesty does nobody any good besides the person practicing it in the short term until they realize that they have allowed a cancer into their minds that will chase their pragmatism out of their ears.
- David
d3x0r
@Nick
I only have half a hint of  an idea of what the issue is... Destructive frequency interferance... similarly if you lay down you kacher it aligns with the grenade and then couples to that resonance... so same if you connect to the antenna (ferrite 0-inductor might be removed) then it also couples to the grenade and it seems something about them is a destructive interferance.
@general
A small note I was thinking about; the last kacher secondary I was using (800 turns 28gauge wire) knocked the resonant frequency down to 227Khz (half of 534 it was on the video) ... which brings the effective capacitance of the coil up to 5.6503nF - that's a lot for just some wire... a higher voltage drive will be able to take advantage of more capacitance (able to move more layers of electrons?)...
need to knock it down to 113Khz next I guess :)
itsu
Quote from: magpwr on December 07, 2014, 08:46:39 PM
hi itsu,
I understand you have done some research on nanosecond pulse in the forum in the past and you have
managed to achieve 800volts peak around 100ns pulse width few years ago in this forum.
Hi Magpwr, more like 1100V at 18ns, see screenshot 1.
That was done on the OUR forum in this thread: http://www.overunityresearch.com/index.php?topic=1556.msg29733#msg29733
Also in the thread we are on right now we were working with 1000V peak at 20ns, see around page 58 or here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg345951/#msg345951
By using other technics, i was able to produce 800ps pulses at 23V  (1:10 voltage divider for measuring purposes), see screenshot 2 and in the
first thread, but later in time: http://www.overunityresearch.com/index.php?topic=1556.msg41213#msg41213
Just yesterday i was again testing the nanopulser, and the pulse reached 1600V at 30ns, so things can still improve.
Most of those articles i have seen,  but thanks anyway.
Regards Itsu
magpwr
Quote from: itsu on December 08, 2014, 02:44:08 AM
Regards Itsu
hi itsu,
May i ask is your circuit able to maintain this high peak at around 1500kv at repetition or firing rate of around 25khz...34khz.
I am curious what ferrite material are you using for your toroid which is coded blue or cyan in colour.
May i ask which circuit are you using.There are many to choose.My requirement is simple to get to 1.5kv at least at around 100ns...300ns which is half time period of kacher 1.66Mhz ~602ns
The latest one i have seen today is attached for reference.
Jeg
Quote from: d3x0r on December 07, 2014, 07:01:32 AM
not really ; the diode itself is a tiny capacitor so...
adding another small capacitance in parallel ... if it's too big, the voltage won't build high enough and it'll be flat... if the capacitor between kacher and grenade is X, the parallel capacitor should also be X or smaller.
It worked alright.... I ended up being able to up 2nF caps and get a decent output; but now I'm only using 25-400pF transfer... so it's not really big enough to count in the resonance... it's kinda how caps work in the LMD (longitundinal magneto something) Dollard transmission line thng...
if you're not direct connected with a capacitor, it won't help you
you can add a tiny cap in series with the diode which will give it less capacitance....
Thanks John :)
At the time i have dismantle my circuit setup to try some things. When i ll return to my initial setup i will try your technique of galvanically connection between katcher and grenade. I remember that stupify had posted once a Tesla drawing showing exactly this. It was a yellow drawing if you remember.
