0 Members and 49 Guests are viewing this topic.
itsu
Good info NoBull,
more great info from verpies regarding DSRD's can be found here:
http://www.overunityresearch.com/index.php?topic=1556.msg26288#msg26288
Regards Itsu
John.K1
Quote from: skywalker66 on December 08, 2014, 08:30:44 AM
You tell me, you are tesla expert.  ;)
I am not an expert, I am only humble beginner lost in misinformation of this world. So I am asking again, what is the difference between the Tesla coil and the HV HF transformer? Thank you for making me this clear on my way to understanding ;)
Void
Quote from: plaxius on December 03, 2014, 07:45:53 PM
Bulb and power supply on ...  tomorrow testing with batteries !!
Hi Plaxius. Have you tried your tests using only batteries for powering the kacher?
If so, did you get any noticeable difference in results with using only batteries?
All the best...
d3x0r
Re Making kacher more stable...
I've been swapping various primaries and secondaries all with pretty arbitrary relationship.
all air cores...
if the secondary is higher inductance, can increase turns on the primary and the closeness of the primary to the secondary so it has better leverage against it... and gets better coupled feedback.  Increasing turns is not nessecarily enough; changing the turns by double doesn't affect the balance of the overall system... that change alone shouldn't be enough to change the octave...
The higher the voltage transform, the lower the resonant frequency can be; the lower the frequency the higher the capacitance linking the kacher secondary and grenade can (should) be.
down to 135Khz with decent output at lower voltage... more current used at a time though so same basic power...
When I first stepped down to this, the kacher was doing pulses... so it would ring up  resonance (as detected by a scope probe laying a distance away on the table ) get to a max, steady out at a level, then cut off... and have a long period of silence.  and then again a ring-up (resonant rise)....
adjusting resistance didn't fix it... was using same (about 8 turn) primary as with other secondaries I had tried... (I've been increasing inductance of the secondary)... tried a large loop 24 turn primary that didn't work very well... now found a tight wound cadeuceus that's about 32 turns that works pretty good; but the signal on the scope probe isn't as strong... so I'm losing a level of transform.  This last secondary was like 32 gauge wire so it is the thinnest yet... so possible it's got current limiting problems too.
re capacitance across diode; if you have the diodes to spare, the AV plug across is less lossy... because it is a small transfer capacitance there, it can interfere with the resonance self-capacitance.. but if they are significantly larger ... should affect the resonance less... (?)
If the diode is heating up; it may be that some capacitance across it might ease the high voltage against the blocking side...
skywalker66
Quote from: John.K1 on December 08, 2014, 09:16:11 AM
Welcome into the club !  :)
Let see...
To make story short,
Those two share a common piece which is that coil, resonator (ie secondary tesla). Beside this they differ as drive means.
As you know tesla trans is driven by VERY, VERY SHARP, HV cap discharge into primary coil at a rate which is a subharmonic of
secondary natural freq., and yes in tesla trans case is involved a primary hv cap, a tuning method for primary in raport
with secondary natural freq;  Kacher is a HV selfresonat autoblocking oscilator, it don't produce that effect called by Tesla "radiant"
it lack very sharp impulses implied in tesla radiant transformer. You can't compare collector impulses from a kacher with
hv cap discharges into primary, from my point of view is a very big difference.
