0 Members and 167 Guests are viewing this topic.
dvy1214
Quote from: T-1000 on December 08, 2014, 05:35:12 PM
Seing problems here with getting katcher working in a way Ruslan showed with high power transmission without killing katcher free oscillations and also there are problems in experiments with grenade coil for receiving standing waves and getting echo current responses from Earth. Obviously that create barriers for moving forward.
What is meant by earth echo? Schumann resonance? And grenade coil reception of standing waves from where?
T-1000
Quote from: dvy1214 on December 08, 2014, 05:43:46 PM
I am refering to the sparks you are getting when the body gets electrostatically charged and is touching ground. These little sparks are carrying some amperage like lightning discharge to Earth and there are possible conditions with getting that trapped inside of cicruit. Also external electrons "donor" source is well known to produce additional power in circuit. For example, you can see that after bit of research what the Secondary Emission in old vacuum electronic lamps is...
dvy1214
Quote from: T-1000 on December 08, 2014, 05:52:08 PM
I can't really considering it is pretty well worked out that none confined(electrostatic) ionization events loose energy in regards to the continuity of energy in a single circuit. Secondary Emission and Multipaction are well worked out. An ionization event like a spark gap discharge actually relies on the townsend avalanche less so on the work function of the metals of the electrodes.
- Dave
T-1000
In http://www.teslauniverse.com/nikola-tesla-patents-685,958-utilizing-radiant-energy there is a plate which can be charged from Tesla coil electric field. The method of charging can be refered as electrostatic. In Kapanadze/Dally/akula/Ruslan devices instead of that plate you get grenade coil which is receiving that charge and also has connection to the ground. Since the antenna from the Tesla coil is "hot" end if you would look in a way it is a capacitor plate the second "cold" capacitor plate is the grenade coil. And due coil geometry the windings are making up standing wave nodes which most likely are functioning as electrons trap when the current is being drawn from Earth and given back...
dvy1214
Quote from: T-1000 on December 08, 2014, 06:09:44 PM
Hmmmm let me digest that... Im sensing some Discontinuity.
