0 Members and 163 Guests are viewing this topic.
stupify12
Hello
You are using a Solid State High Frequency Generator, because this device only produce continouse waveform which is not what Nikola Tesla wanted to perform on his device. So this brilliant Akula has find a way to replicate Nikola Tesla High Frequency Generator and combine with a Kacher which people think is a superimposed controller.
I think the Kacher here works as a Spark Gap that breaks the High Frequency Generator Signal into a sudden Impulse.
The Tesla 1 Wire Transmission is much more elaborated in the Tesla Book. You can see all you need on that book, the conversion of High Voltage with lesser Amperage into a High Amperage thick Secondary..
Meow   8)
Quote from: NickZ on December 10, 2014, 10:41:43 AM
   So, it looks to me that the idea is too radiate Hv pulses from the Kacher onto the grenade's 12, 12, or to the 24, 24, induction coil, which is also connected to the yoke's three turns coil. The three turns coil circuit with it's tuning cap, is also connected to the 25 to 28 turns coil (by the single jumper wire), as well as all three of these circuits (including Kacher) to an earth ground.
So, what's going on here???
  There are three different circuits being pulsed at the same time.
   Has anyone had even the slightest noticeable results, meaning higher output, (bulb brightness), when the Kacher is attached, as compared to without it working?
stupify12
Hi Hoppy,
Can you share me a good TL494 push pull oscillator schematic diagram, like the one you are describing on this post. Thanks in advance..
Meow ;D
Quote from: Hoppy on December 11, 2014, 03:56:50 AM
The description I gave was with both the push-pull and Kacher working. When the Kacher is switched on, the bulb can be taken from low light to full brightness by tuning and then to no light output just by hand capacitance - moving the hand close to the antenna.
This Ruslan setup using the yoke has poor efficiency as a transformer and cannot light a 1000W bulb (with or without grenade & Kacher) very brightly when driven with a Mazilli or TL494 driven push-pull oscillator at 12V or 24V working. This is why I can only get full bulb rated voltage (240V) across a 40W lamp with the help of the Kacher. With a 60W or 100W bulb, the voltage across them drops and therefore so does the light output. As Jeg has commented, your load is way to high to see any significant effect from the Kacher.
Yes, I have tried looping back and nothing happens in respect of seeing any signs self-running. Its time to focus on the concept of operation because the Ruslan device as demonstrated and circuit as drawn is either fake or we are missing a vital part of the build.
magpwr
hi everyone,
There is something i would like to share which is base on my previous experimental findings.
For those whom are using TL494 or SG3525 or UC3825 for the PWM generator.You will notice that even though you preset to a frequency.
This Pwm generator base on my previous observation is that it will slowly drift in frequency at 1 or 2 decimal place.Even though you are using a better capacitor to ensure the frequency stability.
The reason why i stick with LTC1799 SOT23 is that base on few youtube video the frequency drift is in 2nd or 3rd decimal place.The output will be split into 2 via my 74HC132 PWM generator.
But the best approach is to use PLL recall the posting by Enjoykin couple of weeks back.The toroid which is generating the mustache which shot at peak at certain frequency will be fed to LM358 comparator.
The other unofficial approach is the antenna approach  which is fed to dual 4017 to get divide by 60.
Lastly please do not use plastic or plastic bottle to hold the antenna coil in place. Reason is simple although plastic isn't electrically conductive but it is still able to conduct static electricity somehow which dampen the effect.
I do hate placing orders online during this time of the year.Goods hardly reach my door within 2 weeks.
Hoppy
Quote from: stupify12 on December 11, 2014, 12:33:36 PM
Hi Hoppy,
Meow ;D
Hi Meow,
I do not have a circuit diagram of the exact design I used but its close to Ruslan's circuit I modified attached. I suggest you use Itu's mosfet protection components as shown in post no.7511.
