0 Members and 49 Guests are viewing this topic.
Hoppy
Quote from: stupify12 on December 11, 2014, 11:46:06 AM
Hello everyone  ;D
I have read all your post, comments and suggestion. I ask of those who has worked with a Kacher circuit did you get a good results? Anyone?
This is not a discouragement but a suggestion for a better development on this project.
The secret you are looking for has been answered by Enjoykin many times. The Ruslan and Akula schematics are very pleasing to your eyes, but if follow those Coil Winding or Coil Arrangement you end up in failure.. I think all of us here knows that this Ruslan, Akula, and many others which has succeed on this Free Energy device has research only the work of Nikola Tesla. The answer which you think is a secret has already been in you memory drives(Brain).
The very first hint to success on this device is what Tariel Kapanadze called  "Tesla Transformator" which he is actually telling us the Tesla Electrical Transformer patent which also Nikola Tesla elaborate more this device on his Book.
Why the Akula or Ruslan device needed a Kacher circuit? On I have observed, which was also tested by me. When I try to directly connect the Tesla 1 Wire Transmission to the Receiving Transformer the bulb attach will not light even a little, also the capacitor attach in a Radiant Receiving Element fashion is not charging. But if the Tesla 1 Wire Trasmission line is switch thru a Spark Gap, the bulb will light brightly, the capacitor will discharge automatically on its own terminal. When another windings are rectified to charge Capacitor can run a DC motor when attach to this capacitor.
What is lacking is a conversion of this electrostatic charge in a capacitor to be switch by another switching Electronics or Spark Gap that the frequency will be 60hz with smaller potential(voltage), greater amount of current(amperage). Like the Switching Power Supply does on the computer PSU, Convert the stored electrostatic charged in a Conventional way like all of us here knows then feed it back to your device..
Meow 8)
Hi Meow,
Can you please put some flesh on the bones by explaining how the 1-wire transmission system switched through a spark gap is powered?
d3x0r
was fiddling with a small signal transistor; with a high hfe... was trying to get it to get tickled at higher frequencies, and managed to get it... for a bit to be at 2-3Mhz and low power draw, when I increased the power I had it connected to the grenade through a 2.2nF cap and managed to get 80+ volts out... but it stopped.  It was working for a few minutes great...
(mind you 2.2nF is huge for 2Mhz and < 100mA)
Telsa valve.... for blocking/passing impulse fluid currents...
http://www.tfcbooks.com/patents/1329559.htm
Coil reminds me of one loop extruded in a circle...
*shrug*
stupify12
Hello Hoppy,
I think using DIODE is good, but I believe semiconductor are only a waste of energy. I show you how Tesla do it with his old technology rotating wheels, how did Tesla obtain consistent sign of charging to his Very Big Electrostatic Condenser. I mean consistent sign, If the wave is positive it will be put to the Positive Terminal of the Condenser, If the wave is Negative it will be put to the Negative-Grounded Terminal..
On the circuit I have drawn, the sign of the wave that will be charge on the capacitor will match with the polarity of the Capacitor so in every Impulse of the Spark Gap the energy on the Condenser is exponential...
Btw. Dont forget to calculate the quarter wavelength for the length of secondary. If not quarter wavelength, the wavelenth of the velocity of the light disturbance will be Multiplied with odd numbers like 1, 3, 5, 7, 9 .. I think people should begin to study only Nikola Tesla nothing else all the answer you need is described and cited by Nikola Tesla in a very great detail..
Meow   8) 8)
Quote from: Hoppy on December 11, 2014, 02:49:06 PM
Hi Meow,
skywalker66
Quote from: stupify12 on December 11, 2014, 03:17:29 PM
Hello Hoppy,
Meow   8) 8)
YESSS! I see now... Keep up your good work, and let us know when you finish a working replica of Ruslan setup using all these Tesla mambo-jambo  :o
Good luck !
plaxius
Hi friends .... i buyed two batteries and analog amperemeter. Kacher two copper plates no ground.
24V + 0,8 A
40Watts Bulb mid god brigth ..
https://www.youtube.com/watch?v=4jOYR9HLRuQ
With Rectifier and Power Source
http://youtu.be/E6PgoaUgyb4?list=UUC4ts0Na4PvigP0DHvmj9fg
Bless..
