0 Members and 576 Guests are viewing this topic.
d3x0r
Quote from: starcruiser on December 18, 2014, 09:17:55 AM
It sounds as if the Grenade coil is wound correctly. partially, the 3rd & 4th layers need to be wound the same direction as well as the 5th & 6th. The 1st & 2nd are self cancelling, i.e. non-inductive already. my question then is
does the primary coil need to be moved over the area of 1st thru 6th coils to improve performance?
Sometimes
d3x0r
Should put a switch on the load.
When I have my incandescnet bulb across the capacitor, at 7-12V it lights fairly brightly, and the frequency is 347Khz... if I start at a lower voltage it will be about 700Khz.....
If I start with the load disconnected, the frequency of the kacher/grenade is at 1.4Mhz (1400Khz) and I get a high charge on the capacitor, then when I connect the load, it stays at that frequency, and I can turn the voltage up and have a very low current.... and get the light to light again; but it is dimmer... at lower frequency more amps at a time are transferred... but I think that running many amps through the kacher is probably bad.
I'm not exactly sure... I wound a kacher secondary on short PVC joiner piece like 2" i diameter and about 60 turns.. this itself with a 9 turn primary resonates at 1.4-1.7Mhz; and now I can swap to a (800?) turn secondary and it still resonates at the 1.43Mhz... but at a lower voltage with lower current to produce more effective output...
but really the caps need to charge to a level so that the steady input to them is at a higher power (level? factor?) already...
I find that while charged... I see large oscillations on the grenade (1-2V) when power runs out and the kacher stops... this slowly runs down... at very low frequencies I've seen harmonics show up that are 7/13hz... and a 32Khz I see spikes that happen out of the blue.... These things are specific to this one grenade coil I have...
d3x0r
Theory of operation...
Rimstar just did a video on what voltage is... as applied to the energy per unit of current..
This is a page on utilization of gravity slingshot....http://www.mathpages.com/home/kmath114/kmath114.htm
And from 0 additional input, a body can gain more momentum than it initially had...
The one characteristic wave I see is a double hump on one half of the wave....
(similar also to a wave someone replicated on a no-back-emf thread on uhh energetic forum?)
The deeper the dip on the top, the more output seems available for a given input.  The kacher is a lousy, lossy oscillator; and wish I had a generic PWM to replace it.
So I was wondering if there was a process that if I started a large thing moving, could I then bounce something off of it to gain energy.... so the large the mass one could get moving, and faster, the larger gain could be made against it...
'a dynamic star system could be made that multiple black holes orbiting each other, one could reach realativistic speeds'
a.king21
This short video is interesting. A guy tries to explain some elements of the Kapanadze aquarium 2 device.
https://www.youtube.com/watch?v=Lg9O3vCg_Q4
He effectively  puts the Kapanadze secret close to Thane Heinz and Melnichenko.
