0 Members and 563 Guests are viewing this topic.
Hoppy
Quote from: John.K1 on December 20, 2014, 05:21:17 PM
Guys, I saw that clip once in hurry, but what I remember is that the yoke is the invertor and he is re-building it. It is also supply for our kacher. I think he said Akula design as on the drawing will not work. He says the ferite between the kacher and grenade plays VERY important role as provides the "spring " effect of suction of electrons.  He also wasn't happy with "just 2Kw out. He wants around 6KW now :) .  Funny think is that he always reference to what Akula does instead what he does himself. It builds strange feeling in me - something for Hoppy :)
What I find strange is that he can dismantle a 2KW self-runner, as if its not important to preserve intact! Maybe it was never any more than a pile of junk.  ;D
Jeg
Quote from: Ed morbus on December 21, 2014, 04:02:35 AM
Watch
https://www.youtube.com/watch?v=qQacByeFZ6U
Hi Ed, thanks for sharing this!
Is it possible to find some more details? So little consumption with so much output current???!!! This is OU by itself!! Well done!
Hi guys. Off the bench these days due to holidays, but with great interest in your posts. Thanks for keeping this project alive! :)
MenofFather
Quote from: Void on December 20, 2014, 11:01:30 PM
Now with the 11m inductor (24x2, tesla bifilar style) wound on, I am measuring:
With earth ground connected to the layer 1 wire on the grenade:  1.47 MHz
With earth ground connected to the layer 6 wire on the grenade:  1.44 MHz
You can now short inductor and check that will be.
QuoteBy the way, when earth ground is connected to the layer 1 wire, the resonant peaks are
much higher than when the earth ground is connected to the layer 6 wire on the grenade.
That normal. If you conecting to 6 layer, then 2 turns of tin wire (were conected oscilioscope) you must move to first two layers, because only on this layers be max voltage (on ground max curent, minimum voltage).
itsu
Quote from: MenofFather on December 20, 2014, 11:33:26 AM
Itsu, you can test that schematic. Oscilioscope only one (+) conected to 2 turns wound tin wire around six layers. You must found resonance of 37,5 meters six layer coil on about 1.6-1.7 megaherc.
MenofFather,
i used the 9m inductor around the layer 1 and 2 as input coil for the FG, the rest was setup as in your drawing.
The scan shows a sharp resonance peak at 1.445MHz (verified by hand), see screenshot below.
We again have a scanrange of 10MHz, so 1MHz / division.
Like void mentioned earlier, the influence of the 9m (or 11m) inductor around the 1st layer of the Grenade is that it shifts the resonance peak
from 1.6MHz to 1.4MHz.
Regards Itsu
