0 Members and 170 Guests are viewing this topic.
MenofFather
Quote from: Void on December 21, 2014, 01:44:39 PM
Hi Menof.
Shorting the inductor gives some interesting results:
With earth ground connected to the layer 1 wire on the grenade:  2.00 MHz
With earth ground connected to the layer 6 wire on the grenade:  4.42 MHz
All the best...
Ok. Now not short inductor, but you can try conect to 3 turns on yoke trought resonant 0,47 uF capasitor.
Ed morbus
NickZ
  Ed:
  Can you let me know where that hand drawing from Ruslan comes from.
I notice that there is no jumper joining the 3t coil to the 26t coil, as was shown previously.
  MenofFather:  So basically, is the idea is to light a small 10w AC bulb from the grenade's output, using only the Kacher?
  I will disconnect the jumper connection mentioned above, and see what difference that makes on the bulb brightness.
  Is Ruslan now taking from the 3 turns coil output to power the Kacher circuit? Is this new info all coming from his last video?
MenofFather
QuoteMenofFather:  So basically, is the idea is to light a small 10w AC bulb from the grenade's output, using only the Kacher?
Yes, ajust kacher to max brightness on 1,4-1,9 megaherc range on 37,5 m multilayer coil.
QuoteIs Ruslan now taking from the 3 turns coil output to power the Kacher circuit? Is this new info all coming from his last video?
Ruslan think, that Akula use 28 turns coil to feed kacher on start from 12 volts battery. Ruslan say in video, that road ferite (with two oposite coils) must be near 6 layers of that multilayer coil.
