0 Members and 1803 Guests are viewing this topic.
NickZ
  Jeg:
  We still don't know the real working principal of the first Akula device, nor has it been replicated, nor has as the second device, (other than by Ruslan).
  I tried to build both the first and second Akla device, but I don't have the right power supply, or inverter, yet.
  Last night I connected a small bulb to the grenades coil's 168 turns coil, and the other end to ground, only.  Nothing happened...
  I don't fully understand the posted Mazilli diagram either,  the output part. And just how the 50hz is superimposed onto the output coil.  Possibly I need to adapt that part to my current circuit, using the grenade as the output coil, instead.
  Any ideas are welcome.
  Has there been an actual working device for the previously posted 6KW Mazilli/yoke circuit?  I don't think so.
  Wild goose chase?
NickZ
  Or, can anyone at least explain about the double secondary coil on the yoke, (in that video), that is possibly going to the Kacher circuit, as it's input source.
The Kacher is always running, he says?
  Merry Christmas to ALL... where ever you may be.
        NickZ
Jeg
Merry Christmas guys, i wish this year to be an overunity one! :)
Nick, i guess that by feeding 24V dc from main supply to the start of few turns secondary with a diode at the end will do the job. But, i am not sure that this by itself is enough to create all this Ruslan's output power.  I believe that there are good chances if somehow we rapidly discharge the output capacitor on the load. Some pages back there is a proposition for using a relay for this task. Perhaps someone here can help us for choosing the right relay for handling all this discharge power. I hope d3x0r or Void can help us more on this as i have never played with relays and thyristors. Normally we want something able to handle some 4-5A at about 1000V (approximately).
magpwr
hi everyone,
It seems strange i get better light output on my 220volts 60watt bulb upon disconnecting one of the two wires from toroid to IGBT transistor collector.
The maximum output for me is achieved using 1.07Mhz for kacher coil which means my PWM circuit is automatically divided by 60 at 17.83khz at 47% duty.
Total input power =55watts  at 30volts.
1.03uf capacitor from toroid 3 turns to 25 turns bifilar.
I'm curious why 1 IGBT transistor produce better output than 2 transistor.Next stage i will reduce duty cycle from 47% to 23% and use 2 transistors at 23% duty.
I'm using the connection to kapanadze coil base on attachement.Note there is no grounding at 3 turns in this version.
