0 Members and 938 Guests are viewing this topic.
Hoppy
Nick,
The diagram Mag posted shows a bridge rectifier consisting of four diodes to rectify the current into the cap and lamp.Its the square shaped symbol just before the cap. Its also known as a bridge rectifier or full wave bridge rectifier (FWBR). This does much the same job as Ruslan's diodes, except that Ruslan is only half wave rectifying the current.
As I and Mag will or has already discovered, the 12T / 28T yoke coil or toroid in Mags case is quite capable of brightly lighting a 60W lamp without any help from the 3T, inductor, Kacher or grenade coils. I think you have already done this with your Mazilli and yoke coils without the grenade, Kacher and inductor coils (simple inverter action). The grenade can be connected in series with the 28T coil or connected in parallel with it as Mag shows in his latest diagram. However, as I commented to him, the multi-turn grenade is simply shunting (in parallel) with the 28T coil and therefore not doing any useful work, just wasting power.
You comment: "So far, all I've seen is that there is nothing special in the circuitry that Ruslan is using. It looks more like fairly standard electronic oscillators, and Kacher circuits. The only trick is getting all these frequencies synced up.  And making all the proper coils, and wiring connections."  The only trick is the one he uses to hide the power supply!
NickZ
  No.  No hidden PS.  Unless you can show how he is doing it that way...
  I meant that there is nothing special in the oscillator circuitry. So, if the superposition is not the key, then, I don't know what is.
  I was referring to the diagram that Mag posted previously (post 7654), to his own hand drawn one. Sorry for the mix-up. Check his previously made post, (the properly made diagram 7654 post), which shows no diodes.
  Yes, I have run the 500 to 700 watts worth of bulbs just from the induction crt/ and yoke, alone. Pic below.
The Mazzili crt is also just an inefficient inverter system, which any cheap car inverter can outperform.  I'm looking for much more than that.
Hoppy
Quote from: NickZ on December 28, 2014, 04:06:37 PM
I showed a very likely method back in post 7426.
tgraca
I am interested in the schematic. This looks like an active thread, but I think it will take me over 3 months to go through the posts. I'll start now and catch up with you later. In the meantime, if you have a schematic, I may be able to contribute soon. I have a large inventory of new components and from the picture, it looks like I have everything I need... maybe a 3 hour build... I also have 2 grounds in place 30'+ apart. Thanks Nick!
NickZ
  There are several diagrams or schematics to chose from.
  Here are a couple of them:
