0 Members and 101 Guests are viewing this topic.
NickZ
  All well and good, but, we really need a video that will show the turning process. As that's what we can't seem to be able to do properly.
To understand how it all works, we need to make the device and see it work, first. No amount of theory is going to help unless a proper replication is made, using the right tuning methods. As we are all failing at the pulse sycronization level, of the various pulses. And that's what Ruslan or Akula could help us with, if they wanted to. But, do they really want to show us?
   It also seams to me that they may need to have other people demostrating their working free energy devices, (other people's replications), to really prove the point of where the extra energy is coming from.
   Geo: I got my new kacher coil working now, but I still can't seem to tune the device to obtain the needed effect generation.  May have to remove some turns.
    Mosfet are still getting hot. I tried different chokes, but in order to reduces the overheating, the chokes also drop the output power levels.
I haven't found a happy medium, yet.
tgraca
Quote from: GeoFusion on January 11, 2015, 10:52:40 AM
Hi guyz,
many don't understand  how this device is working and
why Ruslan wants you to understand it and try to build if you can.
I will give a tip.
About how these devices work,  you have to understand how it harnesses Ether/Cosmic rays/Radiant energy that surrounds us all
like a sea of energy ( take example for lighting), and convert it into usable heat energy stored within condensers/capacitors.
by storing and using it on demand. it will come out High frequency because of The High voltage system(which activates this harnessing effect) and push pull system, nor will it be 120V or 220V at output unless you have the coiling in such a way ;).
Our planet is not only being bombarded by Radiant energy particles from the Sun and the rest of the other stars continuously,
but it also comes from our Inner sun that radiates it outward.
THe reason why the system uses Ground line and harnessing it this way,
acts like a harnessing Antenna.
One more tip,
" Work backwards with this energy" not the conventional way.
understand how a Telsa coil's top load attracts.
Cheerz :)~
I know I mentioned TheOldScientist videos before, but this first video shows a great way to tune this devise. I review this video regularly
for new ideas... These videos are almost 3 years old, so I apologize if you have already seen them, but they might be worth another look.
https://www.youtube.com/watch?v=Z-QvHSyHOuQ - part 1 - initial tuning with a frequency generator
- 2 grounds and coil charging cap
https://www.youtube.com/watch?v=atlnVNy0IDE - part 2 - better coil build
- 2 grounds and coil charging cap - amp draw is consistent regardless of voltage
https://www.youtube.com/watch?v=5m-88B5zi4A - added microwave transformer, spark gap, cap, diode
- tuning to load, spark gap is critical
He has moved onto other things since these videos, but this may help with the tuning process. I am not even close, but these
are the most clear and concise tuning techniques I have seen so far on the Kapanadze Devise....
br549
Quote from: From other Planet on January 06, 2015, 03:22:17 PM
br549,
thank you very much for honestly sharing ur experiments and results. In my opinion ur fame and fortune didnt go away, but just reached new heights...  :) :) ;D ;D ;)
I for my part really welcome your research in the area of conductor length and mass ratios  :)
Thinking about measuring , not an easy task, especially if ground connections are nessecary for operation and meters, and influence results. Also im asking myself if our known measurement devices and proceedings really tell us truth about whats happening. If there is (standing/longitudinal/whatever) waves making stuff happen in these devices (even including supply leads like described by some), or possibly other anomalous effects occuring at certain points of the conductors, where and how to measure energies IN/OUT at all?
My persoanl aproach here, whenever possible, is to work with rectified and filtered DC at IN and OUT, or try looping, but this might also "kill or shadow effects"... And then, how do i know the DC OUT is from same star like DC IN and can be correctly measured with meters from IN star?  ;D
regards
I am still experimenting with the same little coil. I added a third winding (L3) I am now running both the
Function Generator and the Scope from the 12VDC to 120VAC inverter to eliminate any influence from other
grounds. I cleaned up the experiment a little (got rid of excess wire) makes it easier to play with. L3 coil
was just a length of wire I had laying around (30 inches #24 awg. I am not making any claims here one
way or the other. Just working through the experiments and showing what I did, and how I measured it.
I am probably out in the weeds with this (it not like I haven't been there before) but I am going to continue
experimenting with this particular coil setup for a little while longer, although not sure where to go next.
The input and output wave forms are the same shape and phase. The probes used to measure input and
output (V & I) are the same. The only thing that changes is the amplitude between the input and output
wave forms. I am thinking that since the wave forms are the same, that the scope is calculating all of them
the same way.
Any constructive feedback encouraged.
Here is my video for the attached circuit.
t http://youtu.be/3KLKAn9jnak
Have a great day:
br549
stupify12
Hello,
Your coiling looks much better than anyone who is trying to replicate Ruslan or Akula. If you wound the Primay in halves like CW and CCW together with the Secondary, connect the coils in the center like you did with your Secondary CW + CCW. The Primary coil also will look the same with your Secondary winding.. The result will be a better COP and no BEMF would be felt by the driving Primary coil when the output of Secondary is shorted..
If the bulb won't lit using the CW + CCW Secondary try to lit the bulb with only CW side or CCW side.. Goodluck and think clearly not deeply..
Meow
Quote from: br549 on January 11, 2015, 08:53:30 PM
the same way.
Have a great day:
br549
GeoFusion
Quote from: NickZ on January 11, 2015, 12:35:49 PM
Hi Nick,
Nice man got the kacher working now :). keep on experimenting, it's the only way we all can figure it all out.
sad that the mosfets are getting hot like that and yes the chokes play a big role but remember to place caps and many more to create
a balance (resonance)  and get high output like how I did, the ones befor the ferrite yoke and befor the yoke.
you'll reach.
yes the tuning and synchronization part is a very important when finalizing and part beginning of Ruslan device.
part of reaching resonance. Up till now what I understand what Ruslan is telling  is that
there is  a Resonance Within a resonance happening.
up till now, that I'm able to replicate there High speed Mosfet drivers to test, this will determine everything.
almost done with it, just needs some more soldering and done for the test.
You will need a TL494 circuit to continue this work, will give the effect needed.
yet saw many other replications, but some ppl are missing out how to connect everything, especially the ground sometimes
but I will do as I see on the schemaz.
and to experiment with the circuit on my own.
for everyone, Just maybe I will demonstrate a small device I build last year nov. for the test of particle harnassing effect , has Flyback trans and mazilli, caps and uses ground.
The device only works when the ground is connected. or can generate energy , it harnesses energy from ground. and environment.
it's fun but has amazing effects.
Cheerz
