0 Members and 169 Guests are viewing this topic.
Ed morbus
John.K1
Hi Geo,
Thanks for your video and link .  I have to smile a bit as I have used yesterday two same home made caps :D - In my case I needed two in series to get the inductor coil in to the resonance.
Anyhow,  I do some tests - I have my inductor coil as LC tank with one tap on the bulb and than on ground. The bulb 220V 25W lits full brightnes but the consumption is too high (24V @ 3A)
When I use the clamp Amp meter on the ground wire it shows 7.5 A DC   . When I connected my Analog meter in line it shows only 30mA.  :(
Next -when I connect diode bridge across the bulb, the output is around 280-240V.  I can connect the cap and it charge fine. It charge much faster if I connect only one lead to the bulb and the second lead is free. Ground than on negative side of the diode bridge.  Than I was blinking the 220V LED bulb 3x in second.
Hoppy
Quote from: GeoFusion on January 13, 2015, 09:11:54 PM
Hi guyz 8)
Done uploading the vid,
I promised I would show the device that depends on earth grounding.
Small but has some interesting effects.
It even EMPs my Wifi router completely !!  So no internet when it's on. haha
https://www.youtube.com/watch?v=M1SP9nMVWec
And new Vid of Ruslan, This is a good one with His Full Drawn Schematic, Enjoy
https://www.youtube.com/watch?v=1LhF261VDQw
CHeerz~
Hi Geo,
Thanks for showing your video. This is the first video I've seen that shows the Kapanadze type lamp dimming effect after switch-on. I think you are close. Are you using a Mazilli to pulse the flyback coil?
GeoFusion
Hi there Guyz  ;D
John.K1,
haha Awesome man, so you also know they way of salt water capacitor for some hardcore testing  ;D.
Normally use them for my first spark gap Tesla coil, I think I have a vid of it on my channel.
Nice results and interesting.  Yes when you rectify the output it has a high lv of voltage DC, but remember, it's radiant.
the reason why measuring it is a bit hard. in anycase you where able to light it up :), now try to connect a TL494 generator to it.
mixing is needed here.
Keep on with the experimenting, Keep a close look how I move too and ruslan.
Hoppy,
Hi man, no probs anytime for learning purposes :). This is to show what I understand up till now about Earth ground
Thnx to what Ruslan is showing and doing, it all makes alot more sense now.
Yes that is a standard Mazilli I used there to pulse the Flyback , also used that particular one for earlier roundcore experiments.
Imagine now putting that in place of the kacher on the ruslan device, when you see the schematic.  as example:),
It needs the ground to attract radiant energy particles and depending on your driving force it will harness even more I guess. ;)
and storing it all in caps.
It somehow makes sense now how it should work with Ruslan's device, :) I feel we are almost there.
High voltage is necessary to activate the ground line :)
This is also the new video Ruslan posted and I attached his corrections he drew in his schematic.
https://www.youtube.com/watch?v=XVKhXfUZefc
  Cheerz~
