0 Members and 132 Guests are viewing this topic.
magpwr
Quote from: GeoFusion on January 15, 2015, 12:43:55 AM
Hi Acca,
These are good links for the two latest Ruslan videos.
1ste
https://www.youtube.com/watch?v=nbBbwFiSa0o
2nd
https://www.youtube.com/watch?v=QV29seAheNY
Enjoy man :)
Check out my  new vid where I demonstrate a device that is dependent on ground for it to work
I posted a while ago and when attaching the new Ruslan schema.
Cheerz
Cheerz,
hi Geo,
Thanks for putting up a back up youtube video of Ruslan video.
How to obtain pulse base on 15:48min into video-------
For everyone else whom is new in this forum this the attached nanosecond generator Ruslan is using which was derived from Akula circuit.Do ignore transformer and mosfet it's merely for demo.
Previously i used low value for C3 for attached circuit 470pf to get below <500ns.
Since i know now Ruslan using around 2us pulse which is around 1/4 the period for kacher which is around 600ns for 1.xMhz.
The value for C3 should be increased to 2.2nf to obtain pulse width of 2us which will be fed to TC4420 or TC4452 mosfet driver.
Since we know he is only using pulse on positive peak of sine wave across 0.47uf capacitor.
Which means that input of attached nanosecond generator at D3 will be connected to channel A of PWM generator.
Base on attachment 7daf5eebb4dc.gif  where this nanosecond generator was obtain from Akula circuit.Noticed there is "A" marked in circuit that is channel A of PWM generator for pulse to appear at positive peak.
The output of nanosecond generator was connected to base of transistor for kacher in the old setup.The old transistor driver have been replaced with TC44XX for Ruslan.
I have not tried this approach in feeding nanosecond pulse to base of kacher transistor yet.But i will later this evening since my circuit was already build with nanosecond generator with channel A or channel B selectable.
Do take note at resonance the voltage across 0.47uf capacitor would be lower sine the voltage is div by 1/2 into coil and across capacitor.
I do recall Ruslan did mention somewhere in Russian forum for tuning can use one 0.47uf capacitor but for actual setup it's 2x 0.47uf capacitor + small capacitor in parallel configuration.In order to get 1/2 resonance of 27khz which would vary depending on your DIY winding.
d3x0r
wish someone with a working unit would demonstrate running without the wire through the coil... is it just cable management... or is it the target of a concentrated current....
Here's a new video about birkland (force-free) currents, which happen in interstellar scales.... They are characteristic of a thin fillament of high current with sheathes of opposing currents around them....
https://www.youtube.com/watch?v=yIFR67sckK0
At a Z-pinch is where a star is formed....
could wish to meet more theorists
John.K1
Hi Guys.
What I wanted to say- I am going through the A. Romanov movies as he shows some effects which might be the key in Ruslan's device.  What surprise me is an experiment, where he connects two different coils (one by one) of different inductance's  to signal generator and Amp meter. He change the frequency and check maximum reading on the AmpMeter. One coil has max a 1.8MHz and the other coil at 1.2MHz.  Funny thing happens when he connected ground cable. Both coils has maximum reading at the same frequency value.  Hmm
Cheers
Hoppy
Hi Acca,
Cheerz,
Hi Geo,
As I commented in my last post, you appear to have simulated the Kapanadze lamp dimming effect on switch-on. The earth wire is clearly providing a return path back to your PC PSU. This IMO gives us an important clue to how the Kapanadze green and transparent box devices are working. We even see on your demo how when the earth is disconnected, the lamp still glows but very weakly. This again ties in with the Kapanadze devices which are reported to still work but not so well with the ground disconnected.
As I understand your setup, you have a Mazilli oscillator pulsing the primary of a TV flyback transformer, with its HV output loaded with two parallel connected bottle caps with spark gap. A circuit sketch would be helpful from you to confirm this. We now have an opportunity to discuss and determine how and with what components Kapanadze is likely to have used to scale-up this simple setup. I'm now beginning to believe that it it 'so simple, you'll laugh', well at least in principle!
NoBull
@Hoppy
I don't know what you mean, but coming from you it must mean that it is important.
I wonder if Geo will provide the details that you have requested.
Once you have them (if ever) perhaps you could write a little analysis about what should be happening vs. what is happening.
