0 Members and 57 Guests are viewing this topic.
Hoppy
Quote from: NoBull on January 16, 2015, 05:12:21 AM
@Hoppy
I don't know what you mean, but coming from you it must mean that it is important.
I wonder if Geo will provide the details that you have requested.
Once you have them (if ever) perhaps you could write a little analysis about what should be happening vs. what is happening.
If Geo's build is as I described, then what is happening is what should happen with this simple circuit arrangement. Its important because I think Kapanadze is using the same components but with higher power ratings, albeit with some components hidden.
magpwr
hi everyone,
This is my latest findings for today.
I am now able to light 220volts 5watt bulb brightly merely using kacher with "outer copper coil" over multilayer coil.
Previously this was my setup -
25 turns "bottom" and Multilayer coil "top" along with source negative is connected to ground with the bulb.
Multilayer bottom coil is connected to the bulb.
25 turns "top" is left unconnected in this configuration.
Latest version as shown in photo 25 turns "top" is now connected to 2000volts capacitor 0.1uf and other end of capacitor is connected to Earth.
"Without capacitor bulb just barely lit at 1.564Mhz"
Just take note-This may not be the actual setup base on what i am doing if we are following Akula or Ruslan with no hints.
Interesting thing to note at 1.7Mhz with or without the 0.1uf capacitor.There is hardly increase in current and frequency of kacher is unaffected at 1 decimal place even though bulb is brighter with cap. :)
tgraca
It would be nice to see some COP measurements on these attempts so the real value of these experiments can be evaluated properly.
I have only done a few builds, and so far, my best build has a COP of 7%. Now, with that simple bit of information, you can tell immediately
that my efforts are not even close to anything worth sharing. If I saw 60% or better, then I would know right away that someone
(including me) is on track.
If anyone can, please help me with this one question?
Without COP measurements, how can I evaluate the true value of my efforts in these builds?
I understand the value of replicating theories and others builds only if there is some kind of specified COP. If you are getting better
than 60%, please include that information and how it was measured. Hell... if you are getting better than 7%, you are doing better than me!
lol - Thanks, - Teo
PS - with 2 grounds, 2 inductors and a transistor, I can light an LED with no input, but what I am looking for here on this thread is a way
to somehow trick the Earth into providing more power. Note that the raw power from just the 2 grounds is ~450 mV and ~3 mA. That
is my starting point. I want to somehow amplify this into usable electricity.
a.king21
Quote from: Hoppy on January 16, 2015, 04:32:46 AM
Hi Geo,
As I commented in my last post, you appear to have simulated the Kapanadze lamp dimming effect on switch-on. The earth wire is clearly providing a return path back to your PC PSU. This IMO gives us an important clue to how the Kapanadze green and transparent box devices are working. We even see on your demo how when the earth is disconnected, the lamp still glows but very weakly. This again ties in with the Kapanadze devices which are reported to still work but not so well with the ground disconnected.
As I understand your setup, you have a Mazilli oscillator pulsing the primary of a TV flyback transformer, with its HV output loaded with two parallel connected bottle caps with spark gap. A circuit sketch would be helpful from you to confirm this. We now have an opportunity to discuss and determine how and with what components Kapanadze is likely to have used to scale-up this simple setup. I'm now beginning to believe that it it 'so simple, you'll laugh', well at least in principle!
I've suspected that the ground effect is a standing wave reflection. Why not try the highest voltage of your circuit and earth it through a light bulb. It should work. lol
Void
Hi Geo,
Hi Hoppy. Unfortunately Geo showed no input voltage and input current measurements from his power supply
while connecting and disconnecting the Earth ground. There is no way to draw any conclusions at all without seeing
what is happening in regards to input power consumption. Also, it is normal for high voltage AC circuits using flyback xfmr's and
tesla coils to increase output when connecting one end of the HV output coil to Earth ground. I have seen this effect
on numerous occasions when testing with tesla coils. However, in my tests I have noticed that the input power consumption
also increases when the output increases, when connecting the Earth ground. :) Geo really needs to show what happens
to the input voltage and current from his power supply when he connects the Earth ground. Also, as I have mentioned
before, if you are powering these sort of devices using a mains connected power supply, you can easily be lead down the garden path
chasing 'phantom' ground loop effects. :D It is pretty much essential to do these sorts of tests using only a battery as a power source.
Not sure if Geo used a battery or a mains connected power supply.
All the best...
