0 Members and 844 Guests are viewing this topic.
John.K1
Quote from: a.king21 on January 16, 2015, 09:36:27 AM
I've suspected that the ground effect is a standing wave reflection. Why not try the highest voltage of your circuit and earth it through a light bulb. It should work. lol
This is exactly how my 220V  25W bulb light -very insufficiently :D   Bulb on inductor coil  and ground - IN 60W  OUT 25W    - but - I have not my device tuned nor in in resonance yet. I was watching very interesting Russian movie ,explainingKapanadze coil and now I THINK I do partially understand why coil looks like it looks.  It has to do with the meeting two waves. If they meet in right time they increase, if timing is bad the reflection back occurs.  Now in my head some kind of my design implementing bucked coil :) Anyway as Ruslan said- do understand it!  ;D Time to study.
BTW, I still do not understand how can you get impulse on antenna. It always shows sine wave? Ruslan is using Dali signal generator.
chers.
Hoppy
Quote from: Void on January 16, 2015, 12:00:20 PM
Hi Hoppy. Unfortunately Geo showed no input voltage and input current measurements from his power supply
while connecting and disconnecting the Earth ground. There is no way to draw any conclusions at all without seeing
what is happening in regards to input power consumption. Also, it is normal for high voltage AC circuits using flyback xfmr's and
tesla coils to increase output when connecting one end of the HV output coil to Earth ground. I have seen this effect
on numerous occasions when testing with tesla coils. However, in my tests I have noticed that the input power consumption
also increases when the output increases, when connecting the Earth ground. :) Geo really needs to show what happens
to the input voltage and current from his power supply when he connects the Earth ground. Also, as I have mentioned
before, if you are powering these sort of devices using a mains connected power supply, you can easily be lead down the garden path
chasing 'phantom' ground loop effects. :D It is pretty much essential to do these sorts of tests using only a battery as a power source.
Not sure if Geo used a battery or a mains connected power supply.
All the best...
I agree with what you say. What I'm saying is Geo's setup is how I think the Kapanadze box devices work, power supply included. Kapanadze uses components with a higher power rating, some on view, some not on view. Geo uses a PC PSU, clearly shown in his video. Kapanadze uses an unknown type and rated PSU as its hidden.  ;) If Geo used a battery power supply with no reference to earth, the earthing effects in the video would not be seen.
Void
Quote from: Hoppy on January 16, 2015, 12:50:45 PM
Hi Hoppy. I have seen the Earth connection make a big difference in the output on tesla coil secondary voltages
when connected to Earth ground, when the tesla coil driver was powered from a 12V battery only.
Earth ground can have quite a strong effect on HV AC circuits (even on lower voltage AC circuits as well), but when
I connected Earth ground to the tesla coil secondary in my tests it caused the tesla coil to draw more power from
the battery as well. Certainly resonant frequencies and impedances can change when you connect in the Earth
ground, so that is probably at least part of it. I have put the Ruslan/Akula device aside for the time being as I
find my efforts are more fruitful when I just conduct basic tests of various kinds trying to get a better understanding
of what is normal and what variations might potentially produce over unity. I am moving forward inch by inch, and sometimes
in increments of one inch forward and two feet back. :D
P.S. I said I wasn't sure whether Geo used a power supply or battery because I watched his video a few days ago
and don't have time right now to watch it again. I couldn't remember off hand whether he was using a power supply or battery. :)
All the best...
Void
Quote from: John.K1 on January 16, 2015, 12:47:48 PM
Hi John.K1. I don't speak Russian, so I could well be misunderstanding, but Ruslan's latest two videos appear to show
a circuit configuration that Ruslan hasn't tried yet, as of the time he made those videos. Since Ruslan is planning
to drive the tesla coil with short duration impulses, he may well end up with large HV impulses on the antenna coil.
Ruslan showed that he intends to use the opposing choke winding to filter out the damped oscillations which would
normally occur when you pulse a tesla coil. This might work to some extent, but it remains to be seen how well that
will work. I could well be wrong, but my understanding is that Ruslan is planning to not use a kacher driver on the tesla coil, but
to instead just pulse the base of the driver transistor with short duration pulses (low microseconds duration) and to
sync the timing of those pulses with the inverter driver output, as he showed in his video. I am not sure if Ruslan has
actually tried that yet.
Something odd is Ruslan showed (I think in the second video) that on his other device that was by the wall that he started up,
when he shorted the output capacitor right out the lights did not appear to dim at all. This would seem to indicate that Ruslan
is doing something else on that device than he indicated previously regarding the pulsing of the output capacitor. It would seem
that Ruslan is not above deliberately misleading where ever it suits his purposes. ;)
All the best...
GeoFusion
Hi there Guyz  ;D
Hoppy, Void, a.king, John.K1, and eveyrone els reading.
I will be showing a recording again and with some measurements that are weird and meter  distorted or influenced by the field.,
will be uploading it asap.
I drew the schematic you asked for, might be of great use and for the further build up.
Now I get what you mean, about the kapanadze dimming light effect lol.
Yes when disconnecting ground from the Second setup it only burns the light just a bit with only plasma arc
until you connect ground to cap, the spark becomes white lighting and give sound and amplifies. It receives energy.
Yea man, it's crazy how it operates but we need to understand how works.
First of all we all have to know why the tesla coil needs earthing and amplifies power output.
Remember it collects Radiant from earth.
I did use a 12V battery for the test, but have to buy a new one, used it now for my HHO generator for power.
The 12V battery give's same results as connecting the PSU :)
I'm very sure when raising input voltage like 24V+ or maybe even 120V DC to the oscillator,
it would  turn out to be a extreme lvl of output.  ;D And don't forget the High Value caps to it, 10KV+.
it's for the test.
One thing important I can say is that when I connect the ground, I can't measure 12V coming from PSU or any source, it changes value constantly, and till error sometimes on the meter. there is influence.
I did try to light a 7W in between the ground line and it lights up barely, but that shows there is power there :)!
This reminds me of Chubinidze self running system.
There is a Flyback, with Caps, the Coils And ground earth connected close to the Cap, Without the ground,  lamp does not light. ;)
I'm sure If he used a 7w bulb at the end instead of 1KW bulb when ground is disconnected,
must be able to see the 7Watt bulb light up Dimly
the video of chubinidze self runner.
https://www.youtube.com/watch?v=5nxKqfkkndw
Almost Done with my Ruslan replication for the test ;), see how it works and what I'm able to back engineer and figure out.
   cheerz~
