0 Members and 201 Guests are viewing this topic.
Hoppy
Quote from: Void on January 16, 2015, 01:07:05 PM
Hi Hoppy. I have seen the Earth connection make a big difference in the output on tesla coil secondary voltages
when connected to Earth ground, when the tesla coil driver was powered from a 12V battery only.
Earth ground can have quite a strong effect on HV AC circuits (even on lower voltage AC circuits as well), but when
I connected Earth ground to the tesla coil secondary in my tests it caused the tesla coil to draw more power from
the battery as well. Certainly resonant frequencies and impedances can change when you connect in the Earth
ground, so that is probably at least part of it. I have put the Ruslan/Akula device aside for the time being as I
find my efforts are more fruitful when I just conduct basic tests of various kinds trying to get a better understanding
of what is normal and what variations might potentially produce over unity. I am moving forward inch by inch, and sometimes
in increments of one inch forward and two feet back. :D
P.S. I said I wasn't sure whether Geo used a power supply or battery because I watched his video a few days ago
and don't have time right now to watch it again. I couldn't remember off hand whether he was using a power supply or battery. :)
All the best...
Thanks for your comments Void.
The effects we see in the video are as a result of providing a metallic relatively low impedance conductive return path to the PSU, in comparison with the faint light with no earth connection is as a result of a higher impedance capacitive return to ground. Geo could see if the effect is as strong using a battery but I don't think the effects will be as strong. The bottom line is that a permanently connected user supplied power supply is essential, even if aetheric / telluric energy is in some way assisting the operation of the device. The challenge is to discover the nature of the Kapanadze supply, its location and method of connection. Only then and with proper measurement would it be at all possible to determine if the Kapanadze box devices were indeed self-running.
Hoppy
Hi Geo,
Thanks for latest post as schematic and additional observations. I had not seen this post before I posted my post, so am surprised to learn that you have the same strength of effects when running from a battery supply. I will now build and experiment with your circuit to see if I can replicate your results.
When you do your next video, please show the light effects when powered from a battery.
Edit: Ah! I've just fallen in that your earth connection (the dotted line) is not as I envisaged it. That explains why you are getting the same effects from using a battery supply. I thought your earth ground was the return path  back to the power supply. Just shows the importance of a sketch for explanation purposes! In your schematic 2, the capacitor is raising the voltage level of the voltage applied to the lamp, thus giving a brighter output.
John.K1
Hi Void.  I do not remember everything but I'll tell you what I do.
He said-  Not kacher. This is Pulse generator ( I think he said he use Dali SG) ,  5KV is sufficient enough to get 2-2.5 KW out. No need to go higher.
The electronics in the box is some sort of synchronization to give a puls in right time - the small toroid is a part of it (feedback coil) One small toroid with the light on it it is just for reference-I think.  He said this design is a bit moified but will work better. He has had some problems with the old one- it was burning diodes or so.  The shorting of capacitor show  it is related to the toroid design unit which gives him only 200-250W out.  - Nothing for us :)  Toroid coil was holding the charge -that's why bulbs din't die.
Cheers.
stupify12
  Hello everyone.
                  Nice finding the this set up Geo, I think I cant explain very well  like what you did. I already explain this before on this thread on how I did with this device together with my result . The capacitor on your circuit can be replaced with grenade coil (Tesla Bifilar Coil >>Cylindrical wound=Partnered Output Coils), wind another coil on the grenade coil as our last Output Secondary with greater amount of current/amperage.  Keep on working on this path guys you will greatly be rewarded.
PS. The table is a virtual ground + the buried metal deep in the ground which is the Second Ground. This is the same with the Tesla Electrical Transformer..  HV like to pass to anything which is connected to the ground/Earth..
Meow   ;D
Void
Quote from: John.K1 on January 16, 2015, 03:53:39 PM
Cheers.
Hi John.K1. Thanks for the comments on the videos. I don't really get the bit about the toroid holding charge,
but bits and pieces that don't seem to make sense is nothing new in regards to these type of videos. ;)
That's interesting about the 5KV pulses should be enough to produce 2-2.5kW out. High voltage does seem to be
an important factor in these sort of devices, assuming the devices really do work as shown. :D
Geo:  What's the significance of the dotted lines in your schematics?
Hoppy:  I'm not sure what you mean about the supply, but anything is possible I guess.  ;)
All the best...
