Grumage
Dear All.
Is this perhaps the same effect as GeoFusions?
https://www.youtube.com/watch?v=wNBuUvHDe1k
Length of wire acting as extra capacitance ??
Cheers Grum.
GeoFusion
Hi guyz :)
the next video is loading up shortly . I also discovered something els and it's amazing! :D
When I use setup 1,
and disconnect the earth at the earth pin but leaving the wire  (brown one ) connected to the flyback ground connection,
the end of the wire that should to be connected to earth shoots radiant arcs purple and white arcs on metal objects and just simply on my
cement ground also :o, Burns everything an vacuums.
it even magnetizes stones/ dirt / moss  and even  leafs as a vacuum to the ground line and could pull in any direction !
So like a vacuum for energy also :).
Hoppy,
Ah no problem man ;),  yes same effects when using battery :), Btw the dotted line is Aerial plate. or another ground line for earth. :)
So meaning you could us a earth line instead of the plate connection of large surface.
next videos will show. I wonder what will happen with high rated caps and greater input.
One more thing, make sure there is a second spark gap after the light and the second ground or Aerial plate ;)
Hi grum  ;D,
long time no hear, saw my experimentations? something new came up lol.
I remember that vid you posted :), and yes it does something with wire lenght too.
but it also needs the ground for more power or an big Aerial.
This high voltage behaves like a vacuum  ;D
stupify12,
You are right :), The plate on the bench is actually a ground, or a Aerial, I also connect a second ground now and it works even better.
Void,
the striped dotted lines is Aerial plate or another ground line to earth :)!
   Cheerz~
NoBull
Quote from: GeoFusion on January 16, 2015, 08:00:27 PM
First show some dirt not being attracted by a nearby NdFeB magnet and then later
the same dirt being subjected to your purple arc and finally
show the dirt being magnetized so it can be attracted by the same magnet.
Some people here will have a conniption upon seeing this.
Hoppy
Hoppy,
Ah no problem man ;) ,  yes same effects when using battery :) , Btw the dotted line is Aerial plate. or another ground line for earth. :)
   Cheerz~
Geo,
Yes, the same effects are to be expected with your circuit arrangement when powered from a battery. Additional virtual grounds will increase the capacitance to real ground and lower the circuit impedance, thus lighting the bulb brighter.  :) Greater input voltage should produce more output at an increased input power consumption.
Are you monitoring the input power consumed from the grid whilst experimenting with various ground arrangements? Does a brighter lamp reduce or increase input power consumption? This is the most important factor to establish because Kapanadze claims to run his devices without a battery or grid power supply and can even light lamps without a ground connection!
As Grum has shown in his videos, some really interesting effects can be achieved when playing with HV / HF. With my Ruslan setup I could cleanly switch a 60W light on and off just by moving my hand towards the Kacher antenna. I was the virtual ground!  8)
a.king21
Reminder:  Kapanadze does not just use the effects alone. His patents clearly show that a portion of the output is cycled back to the input: My view is that he creates a static attraction field and converts static to mains electricity. If Geo is already doing that then the next step is to recycle the energy.
